Thread: Intellichem - Intelliph question
    Jul 2012
    Las Vegas
    47
    I am using the EasyTouch subpanel to power and run my Intelliflo pump.
    GOAL: I want to install an Intelliph or Intellichem to integrate w/ my ET to control MA addition to lower PH. I constantly get PH creep even though my Alkalinity is in line.
    Do I have to run the Intellichlor in order to use either the chem or ph controllers?
    I may eventually install my IC60 but right now I'm still using liquid chlorine.
    Thanks
    45k gallon plaster, EasyTouch 8SC, Pentair IntelliFlo VS, IC60, Hayward SwimClear C4020, SwimQuip 1M divingboard, Polaris ATV
    Re: Intellichem - Intelliph question
    No, The Intellichem does not need to run anything.
    Using it to only control MA injection will work fine.
    Easytouch, Intelliflo, Intellichem, Acid tank with pump, Intellichlor and Autelis network interface.
