Results 1 to 8 of 8
Thread: Ordered testing materials.
    Judodad's Avatar
    Jan 2014
    Burleson, Texas
    12
    I ordered the TF-100, magnetic stirrer, Taylor K-1766 Salt Test, & Borates test strips from TFTestkits.net couple days ago. Should be here the 28th. I'm ready to start testing efficiently & effectively!
    17k gal., IG, Pebble Sheen,150 GPM Cartridge CCP420 Pentair 420 Sq.ft Filter, 3 HP Pentair Intelliflo VS-3050 Pump, Letro Legend 4 Wheel Cleaner, 2 HP Pentair Booster Pump, Pentair Intellichlor SWG, Easy Touch Control System With Remote, Intellibrite Led Light, Waterfall, Oklahoma Flagstone Coping, Tanning Ledge w Bubblers, 2 Skimmers, 4 Returns, Built In January 2011.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Ordered testing materials.
    Congrats! You will definitely have the correct tools to do a great job!
    .....and wondering how you ever got by without them!
    You're done SLAMing when:
    Mark R's Avatar
    Nov 2013
    Desert Southwest, USA
    166
    magnetic stirrer is great
    12k gal Gunite/Hayward filter C5520BH with quad 33 inch filters. 2.5 hp motor. Pool is on south side, so full sun light. Spill over spa.
    Laar's heater LT250-Low NOx Gas Fired for pool/spa 250,000 BTU. Roof mount 6 panel solar system installed east/south. TF-100 test kit. May-September 100+ degrees out side.
    Judodad's Avatar
    Jan 2014
    Burleson, Texas
    12
    Well guess I've been lucky so far just using my test kit that my builder supplied me. I don't trust the pool stores when they test my water, so with the TF-100 I'm hoping I never have to go back there again. My water has remained clear since it was filled in 2011 so I guess I must have been doing something right up to this point. Thanks!
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Congrats on getting the right tool for the job. You will have one of the best and accurate kits you can get.
    Jeff
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    You are gonna love the speedstir.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, Judodad
    Once you get that kit, you will be officially dangerous (to algae and bacteria)
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to the forum! Congrats on getting started with the right stuff.
    One tool you'll need more than any other is knowledge. Sounds like you are rarin' to go, so check out Pool School and start with your ABC's. Ask questions if you need too, as we like to help people on this stuff. Good luck and congrats again.
    Essential Links:
