Results 1 to 8 of 8
Thread: Dirt collecting on bottom of pool near jets
    Jan 2012
    Argentina
    36
    Hi
    I`ve been noticing for quite a while that i`m getting a brown dusty looking debris around where our return jets are located , on the floor of the pool. It seems to be worse after the pool has been cleaning. For example it was cleaned this morning, and by this afternoon there were patches of debris all over the place near the jets.
    Any idea what it could be, i`d have expected that the sand filter wouldve prevent things like this, but i get the feeling its not filtering properly.
    thanks
    5300 gallon IG , plaster, sand filter, built Jan 2012,
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Dirt collecting on bottom of pool near jets
    What do you mean when you say "after the pool has been cleaned"? Are you talking about vacuuming/scrubbing? Or chemical additions?
    The two most common culprits are dirt or dead algae. If you can see it at the bottom of the pool, a sand filter will get it, so the filter is likely not the problem. It's either going to be a chemistry problem (likely algae that's being held at bay but still growing in the pool), or dust falling to the bottom due to insufficient skimming.
    Jan 2012
    Argentina
    36
    When I meant cleaning , yes sorry I meant vacuuming, it also appears when the pool pump has been on a while.
    I`ve introduced some algeacide last weekend so could it be just dead algae collecting?
    Thanks
    Mar 2010
    122
    Do you have a sand filter, cartridge, or d.e? Yes it most def could be dead algae
    Jacob Zaluski, Owner
    True Blue Pools LLC. Lexington, KY
    Service Center for Hayward Pool Products
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Yes it could be dead algae. If you touch it and it disappears it's dead algae.
    Jeff
    Jan 2012
    Argentina
    36
    Quote Originally Posted by pwrstrk View Post
    I`m still having issues with the dirt collecting near the return jets. It seems to consist of small particles such as dead algae, dead ants and grass. The filter is about 2 years old and never seen this before until a few months ago. Now it happends all the time, i`m running the pump for about 8 hours a day now and its still not particularly clear and am concerned the filter isnt doing the job. Tried backwashing every 2-3 weeks for about 4 minutes but still getting this collection of particles in the same place. I have to scoop them out with the pool net.
    Thanks
    Smykowski's Avatar
    Sep 2011
    3,065
    Can you post a full set of test results? I should have asked this question at the very beginning.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    I have dead spots where all my debris seems to settle. Try aiming your return jets a little different and see if the stuff moves.
