Results 1 to 10 of 10
Thread: Frozen testing chemicals
    May 2013
    Essex County, NJ
    19
    In the fall I thought I brought all of my FAS-DPD testing chemicals in the house to protect from freezing. I just found an 8oz bottle of the CYA reagent R-0013 in my shed frozen solid. I've heard that some testing chemicals should not be used after being frozen. Is R-0013 a chemical that can be used after being frozen or should I just toss the bottle?
    Pool: 25k gal, IG Vinyl, built 2008, DE, Hayward Progrid 4820 - 96 GPM 48 sq ft filter area, 1.5hp Hayward Super Pump, 3/4hp Hayward booster pump 6060, Aquarite SWG T-Cell-90 Rev 1.40, Hayward Phantom, Hayward H350 heater.
    Hot Tub: 2008 Sundance Cameo, 450 gal
    22,553
    Re: Frozen testing chemicals
    Dave will probably have the definitive answer, but R-0013 is pretty inert. I'd thaw it out and run a test on your pool water and see how it does. You should have an idea of how much CYA was in the pool water when you closed it. Unless of course your pool is frozen.
    30,432
    + 1 what bama said. For that particular reagent, I can't say for absolute certain but my bet is it will perform fine.
    May 2013
    Essex County, NJ
    19
    Hi, I just wanted to close the loop on this. After my frozen R-0013 thawed, I used some to test the CYA level in my hot tub. Results were the same as a test I ran about a week ago. So, frozen R-0013 reagent isn't a problem.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Good to know, thanks for the feedback.
    Essential Links:
    Isaac-1's Avatar
    SW Louisiana
    6,711
    While we are sort of on this topic, does anyone know which test reagents have the longest shelf life, and which the shortest?
    Ike
    38,547
    I think it greatly depends on how you store them. The CYA is inert and the longest ... beyond that I do not know. I have a TF-100 that is over 3 years old that still gives me accurate results (SHHH ... don't tell Dave ) ... although some of the regents have now been replaced when I ran out.
    The dyes, the reagents which provide the initial color in most of the tests, tend to be the most sensitive and last the shortest. The FAS-DPD titrant (R-0871) is also sensitive.
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Interesting topic. I'm needing some 0871 and saw it at Amazon at $10 for (12) 2 oz bottles, cheap! If I could freeze it and make it last 3 or 4 years might be worth it. Here's some good info from Taylor:
    http://www.taylortechnologies.com/Ch...SP?ContentID=2
    IG pebble, 15,000 gallon
    48” PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by JasonLion View Post
    I know this to be true as a general rule. Indicators and normally the first to go.
    Essential Links:
