Thread: Readings after AA Treatment
    1-23-2014
    FC - 0
    PH - 7.2
    CYA - 65
    TA - 110
    CH - 400 ppm
    CC - 0
    TC - 1 ppm
    Questions:
    I want to run these numbers to get feedback on any adjustments I should be attempting. Also, should the FC start to hold shortly?
    History:
    I had some issues with a suction line leak recently so our pool was down for repair. A new line and skimmer box were installed within 3 days of the breach. I chose to treat the plentiful iron stains following the repair with 4lbs of AA. It worked well with the exception for some areas on the walls that I will hit with a sock.
    Action:
    I have been bringing the FC back up slowly (64 oz. 10% liquid daily for 4 consecutive days now). Each day the FC has dropped to zero the following evening except today where it was at 2-3. The PH is holding at 7.2. The water is crystal clear and looks beautiful. I was waiting to see if I started to see some stains come back before I added a sequestering agent. Staining has not returned so I have not added any yet.
    The light bulb went on:
    Prior to getting on this site and doing some reading, I was floating tabs for 2 years. In the summer, I had them in the skimmer box also as I was getting algae even at high FC levels. I read why this was happening and made the corrections. I am sure the leak was caused by the tabs in the skimmer basket. The pool is on a BBB schedule.
    At the time of the repair my FC was sky high and the PH was 6.8. I did not take any other readings.
    Thank you for this incredible site.
    all the best, Brian
    29K 14x37 Rectangular 3' to 9' depth Fiberglass IG, 1.5 HP WhisperFlo, 48 sqft DE filter
    Prv 12:28 - In the way of righteousness is life; And in the pathway thereof there is no death.
    30,432
    Re: Readings after AA Treatment
    Well, you are doing some very good things, but we don't want chlorine at zero for any appreciable length of time. I would suggest increasing your daily FC addition by maybe 33-50% but then monitor it carefully. When the FC begins to "hold" in your pool, reduce your FC addition back to where you are now. Consult the FC/CYA chart for your maintenance level.
    Sequestrant is a preventative and is not good at all at removing new precipitation. It should be in your pool now.
    Product added - Thanks
