Results 1 to 12 of 12
Thread: Updated pics of pool build- Sundek
    We got our decking this week. Indian Wheat Sundek with Mission tan and Bone white aggregate effect (hard to see in the pictures). They are coming back to add more Mission Tan to it this weekend.
    http://www.flickr.com/photos/98595901@N ... 864595916/
    Inground Free Form 20' X 40'; Intellachlor salt system; 8' Super Spa (raised 18"); 18" raised beam with water feature (2- 24" scuppers); 4' bench under scuppers; 7' x 14' tanning ledge with 6" water depth; 2- 3' benches with 18" water depth; Premier In-Floor Cleaning System; Fantastico Travertine coping, tiles, and stacked stone; Sundek decking with travertine inlays; Wet Edge Tahoe Coast ; Aqua Link Electronic Control; Jandy 2HP Stealth Pump for pool; 1.5 HP Jandy pump for water feature; Jandy Heater BTU 400K
    PICTURES OF POOL BUILD: http://www.flickr.com/photos/98595901@N ... 864595916/
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    Re: Updated pics of pool build- Sundek
    Looking good and great design!
    Dave My Pool Build, ODK Build
    22X42 Gunite Freeform 23K Gal, 10X12 Spa
    Diamond-Brite midnight blue, 1800sq. ft Kool Deck
    Pentair Easy-Touch 8, 2-2hp Pentair, 500lb Sand Filter, 400K btu Pentair heater
    Jan 2011
    Richmond, Texas
    595
    Looks great!
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    Thanks, pragmatic (Dave)- looks like you have a whole party area with your pool! Gorgeous!
    Thank you, Flippy! Do you have a link to your pool?
    Readyforapool's Avatar
    Sep 2013
    DFW metroplex
    738
    That looks really good. We are hoping for kool dek or something similar in the fall - budget just couldn't handle it right now. What kind of maintenance is involved? Did they give you any precautions to take?
    Finally Done! - 21x34 IG, SWCG, depth - 3.6 - 4.6 - 6.6, Pentair IntelliFlow 3050 vs+svrs, 60 sq ft Pentair DE Filter, 400k BTU Heater, Polaris 280 w/.75 hp booster pump, Pentair EasyTouch wireless, 38 sq ft raised spa, wet edge Barbados quartz finish - ODK w/36 in Napoleon grill
    Quote Originally Posted by Readyforapool
    Readyforappol - thank you! Basically the Sundek requires regular washing with a high-pressure nozzle to prevent dirt and stains from being ground into the finish. They sent me a maintenance sheet to counteract specific problems that might come up:
    From Bullion Coatings
    GREASE OIL BEVERAGES - FOOD
    Rinse the area with water.
    Apply a solution of citrus-based cleaner or equivalent.
    Lightly scrub the area with a stiff-bristled brush or comb.
    Allow to soak without drying.
    Lightly scrub and rinse thoroughly.
    G Additional scrubbing or applications may be required for stubborn stains.
    Citrus-based cleaners such as Nature's Orange, Simple Green and TSP work very well and are available at home improvement centers and janitorial supply centers.
    HARD WATER DEPOSITS RUST SOIL PLANT WOOD STAINS
    Regular cleaning of your coating by hosing and using a squeegee or push broom to remove standing water is the most effective method of minimizing these stains. If stains begin to appear, clean the area with Lime Away, Whink, or a commercial de-scaler and rinse well.
    Heavier mineral deposits require more aggressive procedures such as a light acid wash.
    Mix Muriatic acid solution. (20-40% acid to water) Always add acid to water not water to acid.
    Dampen the surface with a mist of water. Do not apply acid to dry surface!
    Apply acid solution to damp surface with plastic sprayer or sprinkler can.
    Lightly scrub deck with a deck broom until the solution stops "fizzing."
    When the fizzing activity stops, it is a sign that the acid has finished working. Do not allow solution to dry!
    Rinse off solution with high-pressure nozzle.
    Use a squeegee or deck broom to remove any excess water.
    Neutralize with soda ash, baking soda or TSP - scrub lightly.
    Rinse thoroughly and squeegee or broom off water.
    Heavy deposits may require additional treatments and possibly a stronger acid to water ratio.
    CAUTION: Always wear protective eye and skin wear when working with any acid solution. Follow safety guidelines printed on containers including use of proper respirator.
    MILDEW AND ALGAE
    This type of stain usually occurs in shaded locations where water puddles. If treated early, mildew and algae can easily be removed.
    Mix 50% pool chlorine to water.
    Apply directly onto affected area with plastic sprayer or sprinkler can.
    Lightly scrub the chlorine solution over the affected area.
    Allow the solution to soak without drying.
    Rinse the area completely when the solution has stopped reacting.
    Squeegee or broom water from deck.
    Stubborn deposits require soaking with a more concentrated solution and moderate scrubbing.
    BLACK RUBBER MARKS
    Apply concentrated solution of citrus-based cleaner with sprinkler can.
    Spread the solution over the area with a deck broom.
    Completely scrub the area.
    Rinse thoroughly with high-pressure nozzle.
    Squeegee or broom off water.
    High traffic areas may require repeated applications for maximum results.
    The best maintenance tip for black tire marks is to hose and clean the area on a regular basis to prevent a heavy build up of rubber and asphalt residue. Other good cleaners that can be used include Simple Green, Nature's Orange, Amway LOC or TSP.
    CHEWING GUM TAR TREE SAP
    Freeze with dry ice or CO2 type fire extinguisher and chip off with putty knife.
    Spray remaining residue with Disolvit or Goof Off.
    Scrape off with putty knife.
    Clean area with citrus-based cleaner or equivalent.
    Rinse off any remaining residue.
    PAINT
    Paint that is spilled or sprayed on your coating should be quickly wiped up with a cloth. If the paint has dried, the affected area can be touched up with the Finish Coat. Apply as you would water-based paint. Heavy paint-globs must be scraped off prior to applying the Finish Coat.
    Do not use paint removers!!! These will cause damage to the finish.
    THE FOLLOWING WILL BE HARMFUL TO YOUR SURFACE
    Power Washer With a PSI over 900
    Metal or Wire Brushes
    Full strength Acids
    Metal Scouring Pads
    Sep 2013
    DFW metroplex
    738
    Any issues with scooting chairs around? One comment I read, and it was only one so take it as it is but they said the kids tore up the kool dek pushing chairs around. We've got one family member who's a notorious scooter! Lol
    LOL - I didn't read anything about it, but I will ask the people at Bullion Coatings on Monday.
    BTW: I want to thank you Reillysmommy for all your help and always willing to talk with us about our pool.
    Pearland, TX build ongoing. Freeform pool with Spa. Estimate finish 1st week March, 2014
    Dimensions 37 x 24 x 17 feet. Spa is 8ft round. Approx. 20,000 gallons.
    Variable speed Jandy pump, Jandy Cartridge filter. Aqua pure salt water system. Polaris 280 (black) 3 LED Lights: 2 pool, one Spa.
    Pebblesheen. Blue Granite. Travertine decking and coping.
    Jan 2014
    Pearland, TX
    47
    The inlayin the deck looks very nice. Any more pics
    Hello appleguy711 and Yakag97 ~
    Ever since they updated the TFP site, I am not getting notifications of comments/personal messages/etc...
    Just happened to look at tapatalk and saw these.
    Weather has been too cold/wet to get our wet edge Primera stone.
    Thank you, Yakag97. I love in inlays!!
    Oh gosh! They need to just plaster your job already!
