Results 1 to 7 of 7
Thread: mixing finishes
    mixing finishes
    I have a build going on that you can see in the new construction forum under "new build in South Texas.
    I am going to have two finishes done to the interior of the pool. We are going to due Tahoe Blue quartz throughout the pool except on the infinity wall. We are going to do a Beadcrete finish on that wall. has anyone done or had experience with mixing finishes?
    Re: mixing finishes
    What is the reason for choosing two different finishes? Will they be the same color?
    Support the site
    Re: mixing finishes
    The PB suggested the contrast of finishes. The colors will be a close match but the Beadcrete will certainly be more reflective. We will have 4 LED Intellibrite 5G color lights and 2 of them are somewhat angeled to the infinity wall. I was wondering if there would be a concern of using two different materials? Then I was thinking its basically two different materials suspended in plaster and should not matter.
    Re: mixing finishes
    I think that as long as the finishes are done correctly, there should not be a problem.
    Support the site
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: mixing finishes
    If you're just adding bead to the other mix I don't think it would matter at all. If you are talking about mixing bags of complete mix of different brands, or very different blends, I am betting that the respective makers would not approve. This is anecdotal based on my conversations with suppliers on questions I had, but it might be worth asking about.
    Essential Links:
    Re: mixing finishes
    Brushpup, good question. We never really discussed the make up or application criteria of the Beadcrete. I am not sure if they are going to add the Beadcrete to the Tahoe Quartz.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: mixing finishes
    You might see what they say. Mixing brands may void warranties too. I was quite surprised to find out it was OK to mix different product colors and really surprised to find out you can mix different but similar lines of product by the same maker. Two big names approved of doing that, so some things don't seem to be an issue.
    Essential Links:
