Results 1 to 7 of 7
Thread: Pool leak?
    bear31088's Avatar
    Dec 2013
    Warner Robins, GA
    46
    Pool leak?
    I'm currently losing about an inch of water every 8 -10 hours. Trying to determine if the loss is due to evaporation (pool water temp 49 degrees, ambient air temp anywhere from 25 to 45 degrees) or if I have a leak. No visable wet spots anywhere around the pool or at the equipment slab.
    Any suggestions?
    Thanks.
    Barry
    Barry, Central GA
    15X36 IG 14,200 gal fiberglass pool. Hayward Sand Filter with 1 HP Hayward SUPER PUMP. Pentaire "Kreepy Krawly Robotic Cleaner
    e-mail: oso49@cox.net
    30,414
    Re: Pool leak?
    Anything much over 1/4" in a 24 hour period is not evaporation. You have a significant leak.
    Oct 2012
    Houston TX 77064
    101
    Re: Pool leak?
    when I was losing that much, main drain connection in the skimmer - no tell tail sign of leak. I had two holes in skimmer one to pump, one to main drain. Can cover hole or let water line drop past the skimmer.
    13200 gal, IG, plaster, built 1985, replastered 2012, Mytilus MA-90C cartridge filter, 2716 Blue Line In-ground Pump and Motor (1 HP), (manual clean/brush/test with Taylor K-2006, TFP since 2012) in Northwest Houston TX
    Oct 2012
    Houston TX 77064
    101
    Re: Pool leak?
    did you ever find the source of your leak?
    Oct 2007
    Parkland, FL
    752
    Re: Pool leak?
    Don't you put likea bucket with water on a step and then see if it goes down at the same rate fora leak?
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    38,267
    Re: Pool leak?
    Yup. We call it the bucket test. Ideally you want the bucket to be nearly full and at the same level as the pool.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Pool leak?
    Quote Originally Posted by robl45 View Post
    Here is the link explaining it.....
    http://www.troublefreepool.com/conte...leak-detection
    Essential Links:
