Results 1 to 12 of 12
Thread: Multi-level (multi-height) spa seating??
    Jan 2014
    Frisco, TX
    38
    Hey folks,
    I'm a newbie to the forums. From Frisco, TX. Howdy. I'm finalizing my pool design for a new pool build, and reading this site like crazy to make sure I don't miss anything. (I have built a pool before, but it was 20 years ago, and so much has changed!!)
    Anyway - one thing I've searched for and haven't been able to answer yet...
    What do most people do with the seat heights in a spa? One PB designed 2 heights. Another PB designed 3 heights. And a 3rd PB didn't design any different heights - just same seating around the whole spa. I understand the different seatings are so you can hit different areas of the body/back when seated in front of jets (I think), but what do MOST people tend to do? If you have 6 people in the spa, is it weird that people will be at different heights? (For reference, this spa will be part of a 20' x 40' pool).
    What do you recommend? What are considerations I may not be thinking about?
    Thanks in advance.
    Re: Multi-level (multi-height) spa seating??
    Just had my spa done in 3 different heights. I had the same reservations as you - it seemed a bit weird to me.
    I actually like having 3 different heights - in addition to being more accommodating to different heights, it also allows you to move around based on how submerged in the spa you'd like to be.
    I have one bench that is about 3 inches below shoulders on waterline, one 2 inches below shoulders, and one at neck. I use them all based on my mood!
    28000 gallon IG pool, 3.5ft - 8ft deep, Stonescapes Tropics Blue Interior, Pentair Intellichlor SWG, Pentair Quad DE 100 filter, Pentair Intelliflo VS-SVRS, Whisperflo 3hp (water features), A&A Max in floor cleaning, Pentair Easytouch 8 Automation, Screenlogic II, Pentair Mastertemp 400k BTU heater, Pentair Intellichem with acid injection via stennar pump, 9'x7' spa with Infiniti edge
    wjr75's Avatar
    Jun 2013
    IL
    836
    We have two heights in our spa, maybe a 5" difference. My wife is only 5' 3" tall so she likes the higher bench. I like the lower bench at which keeps the water line right at my neck, I'm 5'9". It looks like the reasoning is for different people's heights.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Nov 2013
    Oro Valley AZ
    99
    We went with 2 heights as well. 18" and 21" (that will be the water depth above each seat). My wife is shorter as well and we figured this would give us options.
    8500 Gallon IG with spa - Blue Granite Pebble Sheen - Pentair 420 Cartridge Filter -Intelliflo VS pump -Mastertemp 400K Heater - Intellichlor IC40 - Easytouch 4 - In final build stages now, should be complete 4/2/2014
    My pool build - in progress
    Jan 2011
    Richmond, Texas
    595
    I would do at least two heights especially if you have any tall family members. My spa is one height and I really wish one side was about 5 inches lower. I am 6'4 and my oldest boy is over 6'6 so we stick out. It really is an issue when it is cold outside and the wind is blowing.
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    Jan 2014
    Frisco, TX
    38
    Thanks for all the replies so far.
    I'm definitely wanting to do some form of multi-level - just trying to decide on 2 heights or 3 heights. It's great to hear you guys are really using the different heights. My last pool a long time ago was "old school", lol, and didn't have multi-level seating, didn't have arm rests, etc. I'm excited about these new features, plus the better jets, the calf-jets, etc.
    bhargraves's Avatar
    Nov 2013
    North Texas
    183
    This thread has been really helpful and came at a perfect time. We have been trying to make the same decision - 3 vs 2 vs 1 height. The only thing giving me minor reservations is that the transition areas are not usable. I suppose it isn't THAT much space lost, and people aren't going to sit THAT close to each other. Our spa isn't going to be huge, so I am a little worried about space.
    Build Complete! : 111ft pool + 8.5x5.5ft spa (12" raised), ~22k gallons, Shotcrete, Stonescapes MiniPebble (Aqua Blue), 3 scuppers, 3 bubblers, Large Tanning Ledge, Long Bench, Pentair: Intelliflow 3050 VS, 1.5HP WhisperFlow (scuppers), Quad 100 DE filter, MasterTemp 400k, IC60 SWG, Intellichem+Acid Tank, 2HP Silencer Blower, travertine decking (~680ft2), dry stack flagstone raised wall / spa spillway
    Jan 2014
    Frisco, TX
    38
    Quote Originally Posted by bhargraves
    Yeah - I know what you mean. The transitions were what was making me shy away from 3 heights. Two just seemed simpler. Plus - like yours - my spa seems a bit small (although I didn't realize it from the pics). Based on researching here, 35 sq. ft. is on the small side, so i'm thinking of stretching it out a bit in my next appointment with the builder.
    bhargraves's Avatar
    Nov 2013
    North Texas
    183
    Yeah, mine is about the size of yours (37 sq ft) - 8.5' x 5'. The problem is, I don't have any space to expand without cutting into the pool, which I don't want to do at this point. I think I am going to go with 3 tiers to accommodate kids, the wife, and me. Good luck with your build!
    Jan 2014
    Frisco, TX
    38
    Thanks. Good luck with yours as well. We are still in the planning stages and it seems like the actual "build day" will never come. And in the meantime, I'm stressing over all these little details/decisions. Ha ha.
    We went with 9.5 x 7.5 interior spa dimensions in a similarly sized pool with one seating height. Having two or even three levels based on what has been said here makes a lot of sense though! I wish I had thought of that.
    Seems to me that the size of the spa would be a big factor - in a small spa, a couple people might be forced to sit at a certain level for lack of space. If you're planning a large spa, you have options.
    Jan 2014
    Frisco, TX
    38
    Thanks for the feedback. I'm meeting with our pool builder on Monday and will see about making it larger, and then talk about 2 versus 3 levels. Definitely don't want to wish it were bigger!
