Results 1 to 8 of 8
Thread: Do I Need a New Pump?
    I'm new to the forum...and need some advice about changing out my pump. I have only one pump that I believe is about 23 years old. It is not too loud and seems to be working ok, but electricity in Palm Springs is very high and I seem to be constantly going into the highest price Tier in the summer which is $.32 kWh. I'm wondering if changing out my pump for a variable speed pump would be worth the expense. My current pump is a 2H and seems to use over 400kWh a month in the summer.
    30,000 Gal. Pool
    Inground
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Do I Need a New Pump?
    Welcome to tfp, db_blazer
    Do you have any high volume water features (spa jets, fountains, etc.)?
    Most likely at your electric rate you can payback a vs pump in a reasonable time. In addition, I think cali has a rebate on some vs pumps to help offset some of the cost.
    Another option would be to replace your current pumps motor with a 2-speed and run on low when you are just circulating pool water.
    Jan 2011
    Richmond, Texas
    595
    YIKES! At .32 kwh I would have my kids on bike hooked up to turn the pump motor.
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    We have a spa...The motor on the pump is an AO-Smith E-Plus. Does that tell you anything? The current pump is a Pentair wisperflo high performance WFE-8. It was installed in 1990.
    30,000 Gal. Pool
    Inground
    I've checked and can get a $200 rebate from Edison Electric.
    30,000 Gal. Pool
    Inground
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    That pump is a 2hp full-rated and moves quite a bit of water, which is good for your jet action on the spa. My guess is that a vs pump such as the pentair intelliflo vs, will payback fast enough (assuming there is a rebate from the utility company) such that that is a better option then replacing the existing pumps motor with a 2-speed motor. The a.o. smith B2984 motor would work for your pool, but I am not seeing it for less than $400 online plus needing a seal-kit. The Intelliflo vs can be had for ~$850 online, and couple that with the rebate, the vs starts looking pretty good although you might have to redo some plumbing to make it fit (not sure on this).
    I'm seeing the Intelliflo pump is a 3HP....I currently have 2HP....Couldn't this cause a problem with the plumbing? I'm thinking that it is too powerful...
    30,000 Gal. Pool
    Inground
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by db_blazer
    The intelleflo will move more water when at it's highest speed, but you likely won't/shouldn't run it that speed....remember it is a variable speed pump.
