Thread: SWG v Nature II
    SWG v Nature II
    My PB is pushing the Nature II over the SWG. I am beginning stages of the project and I originally wanted a SWG. My PB says it is a bad idea due to cost and corrosion. Any feed back would be helpful. Thanks
    38,284
    Re: SWG v Nature II
    Welcome to TFP!!!
    We NEVER recommend and mineral system such as the Nature II {except for use in a hot tub} as the metal that it adds to the water can result in expensive and ugly staining of the pool and turn your hair green. It also does not keep the water sanitized and is NOT approved by the EPA to claim that it sanitizes the pool. Chlorine is really the best option.
    The only problems with SWGs are if you use soft natural stone around the pool and live in a dry climate.
    You could also use an automated method to inject liquid chlorine instead of the SWG.
    I suggest reading a good bit of Pool School
    and you will quickly know more than the builder about the chemistry.
    Also take a look at alternative-sanitizers-and-chemical-free-pools-the-truth-t3025.html and do a search for Nature II for more info.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: SWG v Nature II
    Welcome to tfp, bbt2021
    I agree with jbliz, do not put in a nature2...also avoid ozone and uv systems.
    What part of the country do you live in? Do you plan to have natural stone around the pool?
    Re: SWG v Nature II
    We live in NC about an hour outside Raleigh and are going with stamped concrete. Thanks for the feedback. Any negatives on the Regatta pool line?
