Thread: Freeze coming, pump bring repaired
    Dallas, TX
    227
    Motor repay is in a tire thread but what are the steps to drain everything and protect against freezing temps when pool can't run. I know to pull the drain plug on the filter and pump. I assume the booster pump is ok as is. I have a heater that is not working at the moment, but I know there are drain plugs on it to. Anything else? What do I do about the water in the lines underground. It's going to get down to 23 Thursday night. Not a real deep freeze but just worried.
    new house: TBDK gal IG plaster pool, filter Titan CM DE filter 36 sq ft , 1.5 HP Pump; Polaris 380
    38,520
    Re: Freeze coming, pump bring repaired
    That is not that cold. The pipes underground should be fine. Drain the equipment as you described.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    To be extra safe you could put a tarp over it with an incandescent bulb work light under it, just be careful with placement so the bulb does not overheat anything.
    Dallas, TX
    227
    that is what i was thinking. thanks
