Page 1 of 3 123 LastLast
Results 1 to 20 of 41
Thread: LCD Screen on Pentair IntelliFlo gone bad
    Jan 2014
    El Paso, TX
    38
    Hello. I have had my Pentair intelliflo VS pump just over 2 years now. I just noticed that the LCD screen is blank. it does not show anything. the pump works fine however. I cannot program anything since i can't see what it is i am programming. i check out to replace the screen i need to replace the entire drive kit which costs $600.00. is there any way to fix just the screen or maybe use some external device to program it? thanks
    Omar
    42' x 25' Gunite Pool, 10' x 10' Spa, Horseshoe wading pool around spa, 40,000 gallons
    Hayward Aquarite SWG, Pentair IntelliFlo VS Pump 3HP(main) 011018
    Hayward Pump (spa), Hayward DE Filter, LED Lights, Waterfall, Granite Tile
    22,539
    Re: LCD Screen on Pentair IntelliFlo gone bad
    What's the warranty on that pump?
    Jan 2014
    El Paso, TX
    38
    that's a really good question. I guess I could call pentair with the serial number and ask. do you know what the standard warranty is?
    thanks
    Omar
    Feb 2012
    Phoenix, AZ
    728
    Quote Originally Posted by omsrex
    thanks
    The standard warranty is 1 year. It also depends on if you had it professionally installed or did it yourself. After a bit of research, it does look like you would need to replace the electronics module which is kinda pricey. But before doing that, try giving Pentair a call to see if they have other suggestions.
    I found another thread on here with the exact same problem:
    anyone-ever-have-the-lcd-screen-go-out-on-the-intelliflo-t59505.html
    This happen to my Intelliflo VF pump
    The display circuit board has "NO MOISTURE PROOF COATING", so condensation collects on the bottom side of the circuit board and corrodes out the thin traces on the board. I asked Pentair to pass this information to their vendor for these boards.
    If you have an Easytouch or similar controller, the pump can be programed that way.
    There has been a used "Display" only listed on ebay repeatly for $130.00. http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 1357436018
    The listing expired, you might contact the person, or wait and see if he re-lists it.
    As a side note, You can change a VF into a VS, or VS into a VF by installing the respective Drive Assembly. (Not just the display)
    Easytouch, Intelliflo, Intellichem, Acid tank with pump, Intellichlor and Autelis network interface.
    Jan 2014
    El Paso, TX
    38
    thanks for the replies. instead of getting a new drive for the pump (about$600), is it possible to get some kind of control like suntouch or something else to control the pump and other things?
    Omar
    It depends on how many of the circuit board traces are damaged. Mine worked with an Easytouch (Equal to Suntouch) after the display died. But you will not know for sure until you try it.
    A replacement drive "Display" (used) is the cheapest repair option.
    Jan 2014
    El Paso, TX
    38
    thanks
    what would an easy touch or suntouch go for with my setup? would it be able to control anything else? I was planning on just replacing the drive but i am afraid it may happen again. If i do purchase a drive, is used ok and where should i look? ebay?
    Omar
    thanks
    You will have to shop prices on the Easytouch and Suntouch. Most likely $1000+
    I know that the Easytouch can control either 4 or 8 "Aux" items, lights, pumps, etc
    It will happen again, unless you either; 1) Install a pump rain hood (Dog house) and keep pad dry or 2) Coat the circuit board with moisture proof coating. ( Urethane Conformal Coating P/N 4223-55ML, http://www.amazon.com/dp/B008OA7AWE/ref=biss_dp_t_asn)
    Personally; I would buy the used Display from the guy on ebay for $130.00, disassemble it and coat the board. If when you disassemble the display, you see spots of "green build up" on the back of the board, ask for a refund.
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    Hi Omar, How about posting pics of your pool (sorry if I missed a thread or previous post). From your signature your pool seems interesting and BIG. Good luck with the pump.
    Dave My Pool Build, ODK Build
    22’X42’ Gunite Freeform 23K Gal, 10’X12’ Spa
    Diamond-Brite midnight blue, 1800sq. ft Kool Deck
    Pentair Easy-Touch 8, 2-2hp Pentair, 500lb Sand Filter, 400K btu Pentair heater
    Jan 2014
    El Paso, TX
    38
    so I went ahead and ordered that display from ebay. thanks jerryt.
    I will try post some pics of the pool after i take some.
    I hope this other display works.
    thanks for all the replies.
    Omar
    This will fix the problem for good; Urethane Conformal Coating P/N 4223-55ML,
    Jan 2014
    El Paso, TX
    38
    Quote Originally Posted by jerryt
    Thanks for the info.
    How and where exactly do I apply it once I get the new display?
    Wow, I am sure glad I found this forum. You guys are really helpful.
    Omar
    You take the display apart, and coat the circuit board.
    Don't coat the tactile switches.
    I have a brand new VF display which I plan to do soon...
    Jan 2014
    El Paso, TX
    38
    Can you post pics of it when you do it?
    what are tactile switches? sorry for the stupid question?
    Omar
    What is your timeframe?
    Tactile switches = Tiny momentary push button switches, PCB mount
    Jan 2014
    El Paso, TX
    38
    I am looking to do it probably the weekend of 2/1/14.
    what do I use to apply it? A brush?
    thanks
    Omar
    Jan 2014
    El Paso, TX
    38
    Ok. So here is a pic of my pool. I took it from an upstairs balcony.
    Omar
    The cap of the bottle has a brush built into it.
    Great looking pool.
  20. Back To Top    #20
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    Very nice. Love the area around the hot-tub!
