Results 1 to 8 of 8
Thread: Using a lot of acid...
    Feb 2013
    Melbourne, Australia
    102
    I replastered my pool with Sider Crete about 6 weeks ago and expected that as it is a cement based product, there would be a higher than usual acid demand for the first few weeks. This was certainly true and about 27L later it is still requiring more than I would have thought.
    I am testing at least every second day, and find I need to add between 500ml and 1L of acid depending on the previous use (deck jets, SWCG) to get the pH back to 7.2-7.4, after it has crept up.
    This may well be normal, it just seems a lot. What would be considered "normal" for a 6 week old plaster pool?
    41k litre (11k gal) shotcrete in ground pool, Hayward super 2, Davey Monarch 28, zodiac SWCG
    - undergoing a transformation!
    2nd season Pool Owner. TF-100 testing
    Melbourne, Australia.
    30,415
    Re: Using a lot of acid...
    Yeah, I'd say normal. There really is no "exact normal" and I have no experience with sider crete.
    The primary point to take away is it really doesn't matter. It is mandatory that your pH stay in the 7's for good water management..... regardless of how much acid it takes to keep it there.
    Feb 2013
    102
    I thought it could be the case. I just got a 20L drum so it should keep me going for a few weeks at least!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Doesn't sound bad to me at all. You'll get good use out of the 20L eventually. I wouldn't worry if it were me.
    Essential Links:
    38,274
    New plaster + SWG (aeration) + deck jets (aeration) = ph rise
    What is your TA? If that is high, then that is another contributing factor.
    Mar 2011
    Houston, Texas
    413
    I can't tell whether you've always had the SWCG. If so, I suspect you've always dealt with rising pH.
    About a week ago I turned my SWCG off because the CL went up to 8.5 and my pH immediately stopped rising.
    I suspect that if I didn't have the SWCG I would rarely need to add MA. When my SWCG runs normally I need to add about a quart of MA every 10 days or so to keep my pH in the range.
    9,200 gal. Gunite Luna Quartz French Grey pool with spill over spa, two fountains on tanning ledge (rarely used)
    Pentair Whisperflo 2HP, Pentair CCP Cartridge 420 Sq. Ft., Polaris 280 with booster pump
    Pentair EasyTouch 4, RayPak LoNox 266k Natural Gas heater, Aqua Rite SWCG T Cell 9, Borates, TF-100 test kit
    Quote Originally Posted by HouTex View Post
    Yes, I find that the SWG is a PH raising machine
    Easytouch, Intelliflo, Intellichem, Acid tank with pump, Intellichlor and Autelis network interface.
    Any kind of fresh plaster/concrete surface is going to raise the PH, TA, and CH levels (especially PH). This will happen rapidly for about a month, and then taper off to more slowly for about a year after application. Colder temperatures can increase the amount of time you spend in the "first month" period.
    As others have mentioned, the SWG is also going to cause some PH increase, with the amount of PH increase very much depending on your TA level, higher TA means a more rapid PH increase. By keeping your TA fairly low (60 to 70) you can minimize (or eliminate) the PH increase from the SWG, though high TA fill water can occasionally make that impractical.
