Thread: Sand filters - is bigger, better?
    Hi guys, being new to pools and to this forum - this is what I learn so far in terms of having an efficient setup (keeping power bills down):
    PUMP- bigger isn't better. Get the right size pump, or slower running pump - running longer is better.
    PIPES - Bigger diameter is generally better.
    CHLORINATOR - Getting bigger than what you need is better, you can run chlorinator shorter times - less wear on cell - cell will last longer.
    SAND FILTER?????
    Is a sand filer bigger than what you need better? ie will a bigger pump cause less friction and be more efficient?
    The answer is the missing link to my basic knowledge of pool equipment and efficiency
    Re: Sand filters - is bigger, better?
    You have to have the ability to backwash the sand filter at the proper rate- backwashing too fast or too slow will cause problems.
    22,551
    As cprince eluded to, the ability to backwash properly is the deciding factor. Each filter size has a recommended backwash flow. As long as your pump is capable of producing that much flow, you're fine.
    I don't ever remember someone who had a pump large enough to cause a too much backwash issue. However, I'm sure there are setups out there that could.
