Results 1 to 8 of 8
Thread: First Test Results
    Jan 2014
    Oklahoma City
    5
    First Test Results
    We had a SWG pool put in last spring, as new pool owners we had no clue what we were doing but managed to get through the summer with a clean trouble free pool. This fall and winter we started having some discoloration in the water. It never got bad but it had a slight green tint so I researched and found this place. I've read and learned a ton already and found it was a lack of chlorine that was probably causing my problems. I dropped a chlorine tab in the skimmer and the pool has gotten clear again. I also ordered a TF100 so I can start managing the pool properly, I did my first test today.
    PH 8.2 we have a hot tub that waterfalls into the pool I added ~ 1pt of muratic to bring it back down
    FC- 14 ppm
    CC- 0 ppm
    TA- 290 ppm
    CH- ??? I performed this test but never got to blue water. I stopped added agent at 100 drops. I did go from red to clear with a blueish hint but I never got to a true blue colored water. We are on a well with very hard water. I haven't tested the well water but will.
    CYA- 60
    Does anything else look reasonable? My TA was high but I expect that was due to the high Ph.
    Thanks
    13,500 g SWG pool. West side of house. Pentair intellichlor SWG, Performance Pro Artesian 2, 1/2 HP pump, Pentair Clean Clear Plus filter, Eclipse ozone, Rheem heater, Endless pool system.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: First Test Results
    Welcome to tfp, bratch
    Quote Originally Posted by bratch
    When the kit reads 8.2, the ph can actually be higher. Have you checked it again? If it is still high then add more Muriatic Acid to bring it down and test again after an hour of circulating and repeat until you get down into the low 7s for ph.
    That TA is high but not unusual if you have high TA fill water which is likely since you are on a well (I use well water and mine is ~300 ppm). Test your well water TA and post it here.
    It sounds like you CH is probably high, though your endpoint should be when it turns blue and does not change anymore with the next drop. In your case the endpoint was likely when it first turned light blue. Here are the extended test kit directions:http://www.troublefreepool.com/exten...1.html#p206396 Post your CH results of the well water too, when you do it.
    Be careful with using the pucks, they add cya to your water (though your current cya level seems fine for a swg pool...we recommend 70-80 ppm cya for swg pools). See: http://www.troublefreepool.com/pool-...ater_generator
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to the forum bratch!
    I cant over emphasize enough to read, and work on the ABC's first. Don't get bogged down in anything else in Pool School until you are comfortable with that. If you have any questions, don't hesitate to come back and ask. We enjoy helping people learn to do this on their own. Congrats on the kit, you made a wise choice and when you couple it's use with some understanding, all this will become very easy. Enjoy the forums!
    Essential Links:
    Jan 2014
    Oklahoma City
    5
    Thanks guys. I've read the ABCs several times but will continue to do so until I have a firm grasp on everything.
    I tested the Ph again this morning and it was still showing 8.2. I added some more acid and just retested and had 7.2. I retested my CH and got 375 ppm this time using the 10 ml test.
    I also tested my fill water.
    Ph- 7.2
    TA- 270 ppm
    CH- 375 ppm (10 ml test)
    Should I work it get the TA down on the pool with the fill water being high as well?
    30,432
    Ph- 7.2
    TA- 270 ppm
    This post implies that your fill and pool water are identical in pH, TA and CH.........is that correct?
    Jan 2014
    Oklahoma City
    5
    They appear to be very similar. I could have added an extra drop here or there on the test before recognizing no more color change but I feel fairly comfortable with the results.
    I've had to add acid the past two days to get the pool Ph down it had been reading 8.2 each time I had measured it before this afternoon and the second dose of acid.
    30,432
    Your pH should not be increasing daily by nearly that amount.....probably just being new to the test but test again before you add more acid. It's a little cheaper keeping it down than bringing it back up.
    Jan 2014
    Oklahoma City
    5
    I did not check Ph yesterday after adding acid so it may not have came down too far.
    How fast does aeration raise Ph? Our spa waterfalls into our pool anytime the pump is running so I was assuming that was contributing to the higher Ph.
