Results 1 to 7 of 7
Thread: iAqualink upgrade question
    I'm looking to upgrade my system to iAqualink. I figured I just needed the basic IQ900 since my pool was built in 2011 but some google searches have made me re-think that.
    How do I tell what version of the iAqualink I need? IQ900 or IQ900-RS or other?
    The controller outside by the pool equipment says Aqualink RS system. Not sure how to tell what firmware revision it's running? Do I need to do this to validate for sure?
    The iaqualink website a says 2006 and newer just get the IQ900 and my pool was installed in 2011 but not sure I can just go on that.
    PDA is showing the below diagnostic info:
    PDA-PS4
    Type: Combo
    Firmware:
    PPD PDA 5.0
    J-Box 4.0
    Handheld 3.0
    Thanks for any help figuring this out.
    Mar 2014
    San Antonio, TX
    7
    Re: iAqualink upgrade question
    I am curious about this as well. My pool is being built right now and on the circuit board it says PDA PS8 Combo Rev 7.0. I assume I just need the IQ900.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    RS requires rev R or later.
    PDA requires rev 6 or later.
    One touch requires rev I or later.
    Note: I have discovered that the iQ wont talk to your home wireless network unless your router can broadcast "Band B". Band B is one of the earlier wireless bands. Not all the newer routers still offer B band because it isn't as fast as the newer bands out there (G, N, etc.) If you have a dual band router you can probably make it work. Otherwise, you will need to get a B band router and piggyback or daisy chain it to your existing home router.
    Or you can hard wire. Keep in mind that while hard wire is a better way to go in terms of speed, It requires placement of a network wire from the pool equipment (iQ900 transmitter) to the home router.
    Check with Zodiac/Jandy when purchasing, I would have to think that they will fix this shortcoming eventually if they are to stay competitive in this particular market.
    Factory Warranty Station for:
    Mar 2014
    San Antonio, TX
    7
    Thanks Pool Clown. I missed your reply and just now saw it. So the IQ-900 is what I need, correct?
    malcolmb5325's Avatar
    Sep 2009
    Sydney, Australia
    166
    iAqualink will only work with the RS version so you will have to upgrade to the IQ-900 RS for your old PDA. this should come with a new pcb (with 2 x 485 connectors) and the new chip pcb. The version 7 PDA has the new main pcb so you will only need the IQ900. The easiest way to check is to remove the front panel of the power centre and see if you have 1 or 2 brown 485 connectors (top left hand corner of main pcb) if you have 2 you are good to go if you have one you need to upgrade. But make sure you let them know it is for a Pool & Spa combo or Pool only. If you can run a cat5 cable into the iAqualink it will make it easier to connect. if not make sure you mount the iAqualink aerial as clean as line of sight you can to your router.
    16,000lts Fibreglass, Magna Mineral Pool Water
    Jandy CV340 Cartridge filter, Zodiac TRi SWC, Z4 iAqualink, Jandy Laminar Jets, Solar Heating, Spa Jets with Jandy 1.5hp Epump operating everything.
    Feb 2013
    Worcester, MA Suburb
    53
    Also note that Jandy has come out with version 2.0 of the iAqualink that provides full wireless support, not just the "B" band.
    Dino
    Premier (Esther Williams) 24' x 52" Round AGP (13,500 gl.), Hayward 24" Pro-Series S244T Sand Filter, 1.5 HP Hayward Super Pump, AquaRite SWG, AquaComfort ACT-1100 Heat Pump, Jandy/Zodiac iAqualink Automation System with iPhone App, Aquabot Pool Rover S2-40
    My New Pool
    Mar 2014
    San Antonio, TX
    7
    Ok, thanks....O IQ900 it is. My equipment was just installed and is new (hasn't been sitting around in a warehouse for long. I do have the 2x485 connectors.
