Thread: Jandy Valve
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Jandy Valve
    on the section side is sucking air, but when i turn it from pool to spa it stops sucking air.
    i replaced all the guts this summer , the diverter and oring kit.
    Could the housing be bad ???
    The valve was installed in 1998 , is that past its life expectency ?
    Thanks...
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    22,549
    Re: Jandy Valve
    Post a picture of the equipment pad. I'd be looking somewhere besides the diverter valve
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Re: Jandy Valve
    I found a stripped out screw on the leaking side. Will try to find a oversize one to fit.
    Sean Hannon
