Thread: Motor stuck when removing
    Dallas, TX
    227
    I feel like I am missing something. Undid the four 9/16 bolts, and the motor won't pull away. Feels like it is stuck to the bottom of the front of the stand. Is there a bolt Iim missing?[attachment=1:3d8x542m]ImageUploadedByTapatalk1390066467.433011.jpg[/attachment:3d8x542m][attachment=0:3d8x542m]ImageUploadedByTapatalk1390066477.766583.jpg[/attachment:3d8x542m]
    new house: TBDK gal IG plaster pool, filter Titan CM DE filter 36 sq ft , 1.5 HP Pump; Polaris 380
    Re: Motor stuck when removing
    To change the motor, you remove the band clamp. (The big round silver clamp with the bolt sticking out.).
    Support the site
    Dallas, TX
    227
    Quote Originally Posted by JamesW
    Thanks. That was the issue
    . Now I'm stuck on the impeller screw. Can't loosen using my biggest flat head. Just slips out and don't want to strip it. Any tips? [attachment=0:1hafffnk]ImageUploadedByTapatalk1390073411.306332.jpg[/attachment:1hafffnk]
    JoshU's Avatar
    New Orleans, LA
    543
    It is a reverse thread screw.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Dallas, TX
    227
    Yeah, I found the manual, just says to unscrew it clockwise as it's reverse threaded.
    Found this old thread:
    sta-rite-dura-glas-impeller-screw-is-stuck-t52611.html
    Will try those fixes. I just can't get a good enough grip and a big enough flat head to get it loose. It's always something when messing with pool equipment!
