Results 1 to 9 of 9
Thread: Chlorine level discrepancy.
    Needed pool supplies so had my water tested at pool store. Big discrepancy in chlorine levels. Store says fc is .68 & TC is 3.58. My test using Taylor k-2006 is fc is 9.5 ( shocked a few days ago) and cc is 0. Pool store says put 5# of shock. Water is clean & sparkling with no odor. Which test do I trust. I am thinking mine. Thanks for your help.
    13.5K IG plaster SWG sand filter
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Chlorine level discrepancy.
    Yes, trust yours. Since you have your own good test kit, you're probably better off never taking water to a pool store to be tested again.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    + 1 ^^^. Always trust your own testing over the pool store.
    Jeff
    Thank you
    Isaac-1's Avatar
    SW Louisiana
    6,711
    What they said, but out of curiosity do you know what type of testing the pool store does? drop based, strips, computerized colormetric system, etc? With numbers like their's going 2 places past the decimal I would assume it is some computerized colormetric scanner that reads to high precision, but can still have low accuracy.
    Ike
    Computerized colorimetric
    Smykowski's Avatar
    Sep 2011
    3,065
    Is the computer reading the colors from strips?
    No. They put my water in little bottles and stick the bottle in a little machine.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Trust your own results. There is no telling how far off they are. Any time you mix test results there will be confusion. We have thousands of success stories from those using only good results from reliable test kits.
    Essential Links:
