Results 1 to 8 of 8
Thread: High CYA
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    489
    High CYA
    Had a friend buy a house with a pool and he asked me to show him how to test and balance the water. I take my trusty tfp 100 test kit and find his CYA is over 100 - about 120. I tell him ita too high and how to lower it. He calls his pool guy who tells him it's fine as long as its under 150. Is that a commonly held belief in the pool community? I've never even heard this before so I was shocked. I think he believes the pool guy since the previous owner told him he never had an algae problem in 7 years he lived there. Just curious
    Brian
    20K IG Gunite w/ raised 7ft spillover spa. 1.5 HP Hayward Northstar pump 425 sq ft Hayward cartridge filter, Colorlogic lights AquaRite SWG AquaLogic PS-8 control
    1hp pump for sheer descent
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: High CYA
    It's probably a common belief for those who don't know any better. That's why I've gotten that "deer in the headlights stare" when I've tried to explain the CYA / chlorine relationship to people.
    Jeff
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    489
    Re: High CYA
    The bad advice is coming from 20 year pool guy. Puzzling why the pool hasn't had issues before.
    Brian
    Feb 2012
    Phoenix, AZ
    728
    Re: High CYA
    Does your friend have a SWG? 120 is high regardless, but pools with SWG will normally keep higher CYA levels (70-80).
    Also, as far as the old owner saying 'no algae problems' ...that could be affected by the fact that he wanted to SELL the house?
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    Re: High CYA
    Quote Originally Posted by tagprod
    Sent from my RM-820_nam_att_100 using Tapatalk
    My local pool store owner would concur that CYA up to even 200 is OK. And he has been in biz for 30 years.
    (btw, he measures it using his computer thing.)
    I didnt even consider having a debate with him, just let it be and keep going the TFP way.
    Divin Dave,
    38,238
    Re: High CYA
    Pool companies that only show up once a week have to run the CYA that high (or higher) or all the chlorine would be lost before they came back again. When I fired the pool service, my CYA was above 300. The problem is if algae starts it is much more difficult to get rid of. Pool service companies do not follow our recommendations since they are not at the pool on a daily basis. Trying to mix our advice with a pool service company will not likely work.
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    489
    Re: High CYA
    No SWG at my friends place. All I can do is lead the horse to water. When he calls me because his water is all jacked up, I won't be there. Ok - I'll be there 'cause I like fixing stuff and to bask in the glory that only comes from an "I told you so" moment.
    Brian
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: High CYA
    You can get away with high Cya for a while as long as you run a consistently very high level of FC, but when you get an algae outbreak, you're in deep trouble.
    It takes and enormous amount of FC to SLAM and kill it all. Often a very impractical amount.
    Keeping Cya high DEMANDS keeping high FC, and a little slip lets things go bad quickly.
    High Cya is the number one problem we see when people come here asking for help.
    Essential Links:
