Results 1 to 7 of 7
Thread: How much Acid with Bleach?
    I was wondering if anyone knows - all things being equal - how much acid (31.45%) you should have to add with bleach (8.25%) to keep the pH constant?
    (important note: I don't mean to mix the two together as I prefer not to die from fumes or whatever) I just want to know how much I should be adding to my pool if nothing else is acting upon the pH other than the bleach.
    Thanks!
    Snazzy,
    30,000 Gallons IG, DE filter, SWG, Plaster, 2 HP centurion for filter and same for waterfall, 20+ years old, Polaris 360, hot tub attached
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: How much Acid with Bleach?
    None, any pH change is temporary.
    Essential Links:
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Acid requirement is completely separate from use of Chlorine, while high (over 10 ppm FC) Chlorine levels will skew the pH reading it is self adjusting when the FC level drops back down. Need for acid to adjust pH is varies considerably from pool to pool, factors that can effect it are type of pool (plaster or not), acidity of fill water, amount of aeration, acidity of wind blown dust, etc.
    Ike
    When I used trichlor, my pH drifted down and when I switch to bleach, my pH drifts up. Which is to be expected. As Isaac says, you need to test both and adjust accordingly. Looking at my logs. I've used 5x as much 8.25% bleach as I've use 29% HCl by volume. That's fairly new plaster and my water and soil are alkaline, so things might be very different for you.
    20,000 gal in-ground plaster pool with sand filter. Replastered recently. Mostly adding bleach and acid. CYA was high when I took over.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    It will truly depend on your pool conditions. You're daily chlorine usage will be much higher than your acid usage. That being said you may need to add chlorine every 3 days or so to maintain in a reasonable level you may have to add acid once or twice a month to bring the PH into check.
    Measure, chart, then determine.
    It will vary seasonally, and bather load.
    Smykowski's Avatar
    Sep 2011
    3,065
    In my case, nearly none.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by SwimAustin
    Any upward pH drift when adding bleach is temporary because the reaction of the chlorine conversion process winds up being a net neutral situation.
    Test your pH first, adjust it if needed, wait 20 or more minutes, then add bleach and don't worry about it. Go about your routine and run the pH again tomorrow, or whenever that is usually, then start over. This really isn't something to be concerned about.
    Essential Links:
