Results 1 to 12 of 12
Thread: Weeds through liner
    Jan 2008
    Florida
    1
    Weeds through liner
    I discovered 2-3 weeds poking up through my ABG vinyl lined pool. I plan on pulling the weeds through, from the top, and then patching the bottom with a patch.
    My questions are:
    1) Does anyone have a better solution?
    2) Could I have done anything to prevent this? (I orginally put out the recommended weed killer prior to installation
    3) Is vegetation around the perimeter of a pool a bad thing? (wife likes the look)
    skinsfan44's Avatar
    Jun 2007
    Toms River, NJ
    21
    Re: Weeds through liner
    I am not an expert, but is it possible for a weed to grow through the vinyl liner unless there was a hole there first?
    Kind of late now, but you could have put down some landscapping fabric to prevent the weeds from growing.
    - 18 x 36 Inground with Vinyl Liner
    - 30,000 Gallons
    - Pentair Clean and Clear 420 with a 1HP Pentair Whisperflow
    - Blue Diamond Robot Cleaner
    cant see the weeds growing unless there was light.
    must have been a hole there first me thinks
    15 x 36 Intex AGP
    External skimmer
    Mega sand filter
    1/3 HP pump
    http://s286.photobucket.com/albums/ll82/GazzMan9/
    Quote Originally Posted by scooter64
    My questions are:
    Welcome to TFP!
    There are some weeds that can grow through the liner. No hole necessary!
    1. Until you actually pull the weed, you will not lose much water at all, because the weed is plugging the hole it created! However, your "pull and patch" solution is just about your only option!
    2. I will let others answer this
    3. depends on the vegetation. I would not personally have grass, but non-invasive shrubs and flowers are fine.
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    gonefishin's Avatar
    Joliet, Il.
    413
    My questions are:
    Sorry to hear about your troubles. Weed killer, like Round-Up is dependant on the weather. You can't spray it too early in spring before warm weather kits because the plant needs to be activly growing for it to work.
    Plants around the pool area can look nice. But I would be careful with the selection, trying to stay away from suckering trees or shrubs. Also...a tree that was recently cut down could spread a good number of suckers up away from the stump itself.
    good luck!
    dan
    33' Aqua-Leader AGP
    Hayward cartridge filter and IntelliFlo VS pump.
    Solar Heat coming ; used to own Aqua-Cal HeatWave 100k (HeatPump)
    Aqua-Rite t-15 SWG
    skydiva44's Avatar
    Houston, Texas
    200
    My pool has sprouted a sprig of grass....seems as though I have the same problem as the original poster, but not clear on what I should do from the responses he got, should I pull it out? Not real sure how it got thru sand, tarp AND the bottom of the viny pool, but we did spray before setting up, guess we missed a spot. Any ideas?
    ABG Easy Set 18 x 48
    5455 gallons
    SWG
    Intex Pump 4000 GPM - Size B cartridge
    22,403
    Nut grass is notorious for growing through pool liners. It doesn't need a hole, the sun, or anything else. Most weed killers won't touch it! Round-Up only kills what you can see of it and it'll come right back. At this point, pull it and patch is about the only thing you can do short of pulling the liner and sand and installing a barrier like Gorilla Pad or Perfect Pool Bottom. We installed the Perfect Pool Bottom on ours and it sticks out all around the pool about a foot.
    keri1973's Avatar
    Apr 2009
    Pensacola, FL
    74
    We had the nut grass sprout up in a couple places with our first pool
    We ended up using the gorilla pad this time because of that.
    18ft. Arcadia Round AGP - 19" Sand Filter, 1 hp pump
    Foam cove/ Gorilla Pad/ Wedding cake steps
    Sta Rite Lil' Shark cleaner and Aquabot Pool Rover cleaner - Aqua-Luminator light and return flow w/fountain attachment
    Added Borates 5/19/09 Taylor K-1005 and Taylor FAS-DPD Chlorine Tests
    skydiva44's Avatar
    Houston, Texas
    200
    Thanks guys...we had planned on leaving the pool up year round, so I guess I'll pull and patch! But I am going to check out what a Gorilla Pad and Perfect Pool Bottom are since I'm not familiar with them.
    5455 gallons
    SWG
    has anyone ever seen a weed split 5" thick concrete, or push through 6" of perfect asphalt? Sure weeds can grow without light - a pool liner is nothing for weeds to grow thorugh!
    Dec 2017
    Scranton, NC
    1
    I had my 24' above ground vinyl liner pool professionally installed 4 yrs ago. They did an excellent job and did treat for weeds and nut grass. Unfortunately, last year we had a flood, and it carried invasive bamboo with it, right alongside my pool. I tried all summer, to no avail, to remove this pest from my yard, especially by the side of my pool. First, I tried manually pulling this hateful weed by hand. Finally, I bought the strongest weed killer I could find! I still have bamboo growing, and now have several 5' tall stalks growing in the middle of my pool! I haven't put the cover on the pool this year because I do not want to ruin my new cover! And yes, it grew thru the liner and just in several weeks this fall! This is not the "ornamental" nice kind of bamboo, but grows like kudzu around here! Guess I will need a new liner. Will try to repair, but don't know if I can...how many MORE roots are growing under that liner? But a new liner is out of the question until I get the bamboo gone. Anyone with any suggestions?
    cfherrman's Avatar
    May 2017
    Hays, Kansas
    641
    Check your county extension office, typically they carry info on killing known weeds. Check with local farm supply stores for real weed killer. A quick duckduckgo search yielded this result.
    No product will work if not used properly. For weed killers to be effective on bamboo, you must first cut down the bamboo to the ground. Then allow some new leaves to grow and apply a glyphosate product to those leaves. Diclebenil and selective grass herbicides also work best when the bamboo has been cut first. Use all products according to the label's instructions for best results.
    Leave the liner in to block sun and clip the shoots down inside the pool, outside the pool develop your method that works and when you have repeatable success, trash the liner and work inside the pool and then reline when done.
    Intex 24' x 52" Closed for 2017/18 Winter
    2 Main Drains, hard lined 1.25" and 1.5" PVC
    1/2 HP Intex Pump w/ 42 lb 13" Sand Filter
    TF-50 and Taylor 2006 Test Kits
