Results 1 to 10 of 10
Thread: Is this Liner gap to big?
    I am having hard time accepting that this liner join line is acceptable. The picture below shows where the border portion of the liner is joined. There is an ugly white gap, which takes away from the tile look. This eyesore is right at the entry of the large roman steps to the right. The liner is by VynAll. What does the forum think?
    30,403
    Re: Is this Liner gap to big?
    I hate to complain about minor aesthetic stuff but that is really an eyesore and I think you have a valid gripe.
    Oct 2012
    Houston TX 77064
    101
    I have never seen anything like that, and if it is where you enter by the step, you know people will be asking you every time - a constant reminder "I should of had that fixed when it was installed".
    13200 gal, IG, plaster, built 1985, replastered 2012, Mytilus MA-90C cartridge filter, 2716 Blue Line In-ground Pump and Motor (1 HP), (manual clean/brush/test with Taylor K-2006, TFP since 2012) in Northwest Houston TX
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I agree . Your eye will be drawn to that. Let us know what the outcome is.
    Jeff
    Thanks for the validation. The builder and liner manufacturer have agreed to replace it.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Quote Originally Posted by GTIz
    My liner is by VynAll too and it isnt anything like that at all.
    hope you get it worked out.
    Divin Dave,
    Oct 2012
    Houston TX 77064
    101
    Don't forget to blog with follow-up and pictures of the new install. Good luck!
    Mar 2010
    122
    Typically they should put the seems where the steps are so when you cut the steps out you don't see the seem anywhere. The pool builder should have marked where the steps are located on the original measuring sheet. At least that's the way I do it with our manufacture. (GLI)
    Jacob Zaluski, Owner
    True Blue Pools LLC. Lexington, KY
    Service Center for Hayward Pool Products
    Oct 2012
    Houston TX 77064
    101
    did you ever get ever get resolution on your liner?
    Feb 2012
    Maryland
    400
    For the record, Vynall is a standup company! They will take care of you.
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
