Thread: Placement of jets in spa - advice needed
    Nov 2013
    Oro Valley AZ
    99
    Does anyone have any advice of where to, or where not to place the jets in a spa? The PB is coming by to get the plan sorted out, but I want to make sure I understand any upside or downside to where they are placed. I have never had a spa before... so any help would be appreciated.
    Here is the shape of the spa - roughly 6'x7' - 5 jets
    Thanks!
    8500 Gallon IG with spa - Blue Granite Pebble Sheen - Pentair 420 Cartridge Filter -Intelliflo VS pump -Mastertemp 400K Heater - Intellichlor IC40 - Easytouch 4 - In final build stages now, should be complete 4/2/2014
    My pool build - in progress
    Missouri City, TX
    73
    Re: Placement of jets in spa - advice needed
    From my experience, you generally want the jets where people would sit, or next to them. I would see if you could get 6 jets and have 2 equally spaced on each wall with a seat.
    Steve
    20,000 IG WetEdge Satin Matrix Northshore Plum, Filled 8/24/12
    Jul 2013
    Prosper, TX
    133
    Or two on either side and one on the end if you can't do six.
    18,600 gal, IG, Jandy 60 sq ft DE filter, 2HP VS pump
    Stonescapes Tahoe Blue mini pebble
    Great thread.
    I am in a similar spot. Also.... depth? How deep to go in the center of the hot tub?
    Pearland, TX build ongoing. Freeform pool with Spa. Estimate finish 1st week March, 2014
    Dimensions 37 x 24 x 17 feet. Spa is 8ft round. Approx. 20,000 gallons.
    Variable speed Jandy pump, Jandy Cartridge filter. Aqua pure salt water system. Polaris 280 (black) 3 LED Lights: 2 pool, one Spa.
    Pebblesheen. Blue Granite. Travertine decking and coping.
