Results 1 to 8 of 8
Thread: Which infloor pop ups go where?
    Dec 2013
    Mesa, AZ
    11
    Well, I think I may have screwed up.
    I have a six zone/14 head pop up infloor cleaning system. After repairing broken T-valves considerable debris fell into the system.
    It was clear that the debris was clogging the pop ups so (here's where I messed up), I took all the pop ups out at once instead of one at a time. Five of the 14 have small orifices and 9 large. Now I don't know which ones go where and don't have a pool builders diagram to help me figure this out.
    Hoping someone has a solution to this issue.
    Paul L. My pool: Shasta built 9900 gal Pebble Tec (installed 3/13/2001), Hayward Northstar 1 1/2 hp pump, Hayward C4025 (400sf) cartridge filter. Aquarite Salt system. Quik Clean in floor cleaning system. TF-100 kit.
    22,551
    Re: Which infloor pop ups go where?
    Can you post a picture or a drawing of how the heads are laid out in the pool? That should help figure out how they should be installed.
    SCCS's Avatar
    Sep 2008
    Left coast
    79
    On my setup the smaller orifice are in the steps area and the larger ones go in the main body of the pool. Kinda like starting small at the top and getting bigger going down hill to the main drain.
    16,500 gal Roman end with PebbleFina finish
    4 x 160 intelliflo pump
    Easytouch controls with an IC40 chlorinator
    Sta-rite cartridge filter
    A & A infloor cleaning system
    Pentair 5g LED pool light
    Dec 2013
    Mesa, AZ
    11
    Quote Originally Posted by SCCS
    Hmm. Pool bottom has eight pop ups and I have 9 with large holes. My steps have 5 pop ups and I have a bench at far end of the pool with one popup that sits 18-24 in lower than the pool surface.
    If you need more info I'll diagram post pictures.
    Thanks!
    Dec 2013
    Mesa, AZ
    11
    Here's a rough diagram:
    22,551
    I would put the small ones on the steps and the rest in the pool and the last large one on the bench.
    Dec 2013
    Mesa, AZ
    11
    Thank you!!
    SCCS's Avatar
    Sep 2008
    Left coast
    79
    Not sure which popup heads, but if you have these heads. http://aamfg.com/gamma3CleaningHead.php You have 4 nozzle sizes to choose from. They come apart but not easily.
