Thread: Using ascorbic acid for stains
    Oct 2008
    Yuma, AZ
    33
    I plan on using the "AA" process with Jack's Magic Stain Solution 1 and Jack's Magic The Pink Stuff as the sequestrant agent. I have identified the stain in my in ground fiberglass pool as an iron stain.
    Question: Has anyone had experience with the products mentioned being used in a fiberglass pool?
    14,000gal IG Fiberglass pool with 850 gal spill over spa, Whisper Flo 1hp pool pump, Whisper Flo 2hp spa pump, DE filter, Zodiac Clearwater LM3 SWG, "Heat Siphon" Model SX5HP pool/spa heater, a water leveler and a Kreepy Krauly cleaner
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Using ascorbic acid for stains
    Cannot state that I personally have used these products in a fiberglass pool, but I can tell you that Jack's Magic sequestrants are what we recommend. The Pink Stuff (regular) should work best for you as is more aggressive on iron stains vs. The Blue Stuff. Here is more info: Metals in the Water and Metal Stains and Ascorbic Acid Treatment.
