Results 1 to 8 of 8
Thread: Calcium(?) buildup in my salt generator
    Jul 2012
    Cupertino,CA
    45
    Mod edit: Please only make one post for each subject. People who can help will find it in whatever sub-forum you post it in. I have deleted you other topic. Thanks, moderator linen
    I have a Jandy aquapure 1400 that I have had to change because of cell failure. Though I admit that I probably didn't acid wash it frequently enough, I was disappointed that the cell only lasted 3 years.
    I have just installed a new cell and am looking for suggestions for reducing the calcium build-up.
    The local pool supply store has recommended using a borate product that lists, among many other benefits, the prolonged life of salt cells.
    I'd like to get some input before I do this. If cell life if my main concern (currently), would a borate product be a good solution? Are there other solutions to reducing calcium issues?
    Thanks in advance,
    Mike
    PS, I will post the same question in the chemical forum as well, as my question regards both the salt generator and possibly using chemicals to help it.
    12,000 Gal plaster pool & spa.
    Jandy 2.7HP V.S. e pump, with IQpump control.
    Jandy AquaPure 1400. Jandy PDA.
    Solar heat. Jandy 400btu ng heater.
    Pentair 420 cartridge filter. Polaris 360 sweep.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Calcium (?) build-up in my salt cell
    The use of 50 ppm Borates buffers the pH to reduce the rate of pH rise. Roughly speaking, it cuts down the amount of pH rise in half at the hydrogen gas generation plate in the SWG cell. So yes, the use of Borates help reduce calcium carbonate scaling in the SWG cell. Maintaining a somewhat lower Calcite Saturation Index also helps.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Calcium(?) buildup in my salt generator
    3 years is on the short end for cell life, how big is your pool?
    Are you following the tfp recommendations for chemical levels? See: http://www.troublefreepool.com/pool-...ater_generator
    Many of us on here rarely need to do acid cleaning of our cells by keeping our pools in the ranges mentioned in the link.
    Borates can help, but you should get your TA down to 80 ppm before adding them. Most likely the ps version of borates will be significantly more expensive then boric acid you can buy online or the other alternative of using borax and Muriatic acid to raise borate levels. See: http://www.troublefreepool.com/so-yo...how-t4921.html
    Post your latest measurements for TA, ph, CH, cya, salt level and we may be able to help you reduce the likelihood for cell scaling.
    Jul 2012
    Cupertino,CA
    45
    Thanks for the quick replies, folks.
    The pool is small.
    11,000 gallon
    plaster
    aquapure 1400
    solar and gas heat
    Pentair 320 cartridge filter
    2 HP pump
    spa, with air pump
    Jandy PDA
    No, I have not been following the tfp recommendations.
    I have been way too complacent about maintaining chemicals, and now am paying the price.
    I will do a complete water test this weekend and post the results
    Thanks again for the replies.
    I'll be back
    Mike
    Jul 2012
    Cupertino,CA
    45
    I'm back and interested in your advice.
    Linen suggested that I post the recent test results.
    Salt - 2500
    CH- 250
    CYA- 70
    TA- 160
    pH- 8.0
    In addition, I found that my phosphates are high.(250)
    I have spent some time this week with the "pool math calculator".
    I know that I have to add acid to correct the pH and TA. I have some phosphate additive. (Phosfree) to bring that count down.
    What I am really interested in though, is suggestions for reducing future cell scaling.
    My new cell is working, and I am thrilled. I'd like to keep it that way.
    TIA,
    Mike
    I wouldn't worry about the phosphates. Getting the pH and TA down should be your priority.
    Support the site
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Keeping ph down (below 7.8) and lowering TA will help with reducing cell scaling. Shoot for 70-80 ppm for TA as the swg balance pool school article suggests. If you still get cell scaling after that, then trying borates might make sense.
    Jun 2011
    Long Beach, CA
    2,790
    Too high of pH and TA are causing the scaling in the cell. Use the ranges that the others have said and the scaling will be reduced. For now, check the cell monthly and gently clean the scale off with a piece of wood such as a chop stick. Only use acid when the scale does not come off with the chop stick. Borates will help to reduce the scaling also, but monthly checks will help prevent the large build up of scale.
