Results 1 to 7 of 7
Thread: pentair multiple pool lighting
    I have one of the Intellitouch automated panels with the 8 relays. One 5G pool light one 5G spa light and 2 led lighted bubblers.I would like to control these lights independently but was told I would have to have a transformer for each one and that the relays were for high vol. only. Has anybody hooked up more than one light to this type of panel with one trans. and controlled separately? Keith
    Re: pentair multiple pool lighting
    I am still learning about my Pentair Easy Touch 8 IC40 system. It can control preset light shows or you can program your own show. I am still trying to calculate if I will have some circuits left over for power to separate outlets though on mine for cabana, etc. Here are 2 Pentair links that should help you out some.
    https://www.pentairpartners.com/prod...Automation.pdf
    https://www.pentairpartners.com/prod...6_Lighting.pdf
    34,000 gal, IG vinyl lagoon shape, Pentair intelliflo varible speed 3hp varible speed pump, 2hp varible speed sheer descent pump, 520 clean an clear cartridge filter, letro legend with booster pump, 8ft bench with two 3ft sheer decents, 3 Pentair Magic Flow Laminar Jets, Intellibrite 5g led lighting, Build currently in progress
    Thank's but I'm trying to find out if I need a separate transformer for each light for each relay to control 3 lights separately.I talked to a salesman at a supply house and he said he has many contractors that do this with one trans. but doesn't know how. I thought I could just feed the low vol from the trans to each relay and just hook up each low vol light to the same relays but was told to much resistance through relay for the low vol lights. One light one relay one transformer does not sound to good to me.
    The transformer can stay powered 24/7
    Then you add an enclosure which will be for lighting relays (Low voltage lighting should not be in the same area of the Intellitouch high voltage relays) The relay area is "High voltage only", but the relays themselves can control low voltage lighting without any issues. (The 3hp relays are 25 amp relays, the 5G lighting requires about 2 amps per light)
    Route the relay control wires out the "low voltage passageway" of the intellitouch to your low voltage lighting enclosure.
    PROS - independent light control
    CON - small wattage drain to power the transformer 24/7
    Easytouch, Intelliflo, Intellichem, Acid tank with pump, Intellichlor and Autelis network interface.
    Thanks for the reply. The relay control wires plug into the back of the intellatouch control board. Do you mean take the relays out and put them in there own enclosure and then cut the control wires and extend them into the new box?
    Quote Originally Posted by kkwind
    Thanks for the reply. The relay control wires plug into the back of the intellitouch control board. Do you mean take the relays out and put them in there own enclosure and then cut the control wires and extend them into the new box?
    Correct
    You may also choose to use any relay rated for the proper amperage (2 amps for 5G lights) and fitted with a 24 VDC coil. So these relays can be smaller, cheaper, and use whatever mounting type you prefer.
    Low voltage wiring and High (120v) voltage wiring need to be separated physically. Just as the low voltage passage way on the Intellitouch is separated from the High voltage (Relay?) compartment.
    Thank you, that makes perfect since to me. I probably could have saved some money by just buying the logic board and a sub panel instead of the whole 1200.00 intellitouch since I'm a A/C contractor I have access to all kinds of relays. Thanks again . Keith
