Thread: Joining union and PVC pipe
    Mar 2013
    CT
    351
    I'll be using these as unions on my pool pump. Do I need some sport of special glue to join this union (which is ABS) to a PVC pipe?
    http://www.aqua-man.com/row_num.asp?Ic=5459
    Thanks!
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Joining union and PVC pipe
    Not particulalry special, byt you need a multipurpose solvent. It will probably be labelled "PVC, ABS and CPVC" clearly on the can.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    John is correct. You need ABS compatible primer. Don't use regular primer on ABS.
    Essential Links:
