Results 1 to 7 of 7
Thread: Hayward Tristar VS
    Dec 2011
    Charleston, SC
    100
    Hayward Tristar VS
    Is there anyone that has the Tristar VS already? What do you think?
    I can only find the Tristar model above online in one place. (http://www.polytecpools.com/hayward-tri ... 10842.html) Anyone else know where I can find it? Hayward rep said they only found it there as well. Its so new that I am having trouble find it.
    Looking to install one of the three pumps
    Hayward Max-Flo 2300VSP (Found online for $609)
    Hayward Tristar SP3200VSP (Found online for $899)
    Hayward Superpump 2600VSP (Found online for $665)
    and am leaning towards the Tristar due to its programming capabilities. If I got the superpump or maxflo, that would mean I had to manually switch settings when I wanted another flowrate, correct? I have only a mechanical timer right now.
    If I were to install a VSP, do most folks operate it at a high rpm for just a couple hours (maybe with the robotic cleaner and booster pump) and then operate at a lower rpm for the remainder of the day? Hence the need for the extra programming, correct?
    Thanks in advance for all your replies.
    IG Gunnite Pool Size: 25K gallons (20 x 40, 3'6" to 6" depth) with 2 huge Baker Hydro cartridge filters under the skimmer baskets on the suction side, 2 mech timers
    BRAND NEW PLASTER! Quartzscapes/Diamondbrite, Newer Polaris 280, Brand New Hayward Maxflo VS, Brand New Pentair Intelichlor
    I will conquer the black algae this pool season!!!
    38,246
    Re: Hayward Tristar VS
    If you currently only have a 1HP pump, the smaller cheaper VS should be plenty.
    No you do not have to manually change the speeds. You would use the timer to turn it on and off and it would run through a set of speeds for a set amount of time. Here is a brief post about how they work:
    pool-pump-replacement-questions-from-a-newbie-t72697.html#p604577
    Many people run on high for a short period of time (for a cleaner or skimming) and then on low for most of the time the pump is on.
    Dec 2011
    Charleston, SC
    100
    Oh this makes my decision very easy now...MaxFlo it is!! Thanks for the post. Now to find a post on the do's don'ts of DIY MaxFlo installations. You made my day and my decision so much easier!!!
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,075
    What pump do you have now? Is it 230v or 115v??
    Dec 2011
    Charleston, SC
    100
    230...so still good I think.
    Jul 2011
    Eastern Ohio
    7,075
    Yep.....all VS pumps are 230, so now unless you currently have a Hayward SuperPump, then it looks like the MaxFlo is still your best fit. The plumbing for the SuperPump is the same for both the non-VS as well as the VS, so for many the extra cost can be justified by not having to redo any plumbing.
    Dec 2011
    Charleston, SC
    100
    We have a Hayward RS750 now....
