Results 1 to 15 of 15
Thread: SS Bolt Found in Strainer Housing-Repair Update
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    I found yesterday in the strainer housing (but under the strainer basket) a SS bolt; looks like #7 or 8, about 2 inches long. Pump/motor are working normally. Pump is Standard 2HP Pentair SuperFlo. Any thoughts?
    Dave My Pool Build, ODK Build
    22X42 Gunite Freeform 23K Gal, 10X12 Spa
    Diamond-Brite midnight blue, 1800sq. ft Kool Deck
    Pentair Easy-Touch 8, 2-2hp Pentair, 500lb Sand Filter, 400K btu Pentair heater
    38,248
    Re: SS Bolt Found in Strainer Housing
    There is no way for a screw to get there in normal operation. Guessing you do not winterize which could be a way for it to end up in the pump while pulling things apart.
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    485
    Sounds like an impeller screw, but I don't think the pump/motor would run fine without it.
    10,700 gal IG vinyl
    Pentair Triton II TR50 sand filter
    Hayward SharkVac XL cleaner; Emerson 1HP pump
    Bioguard Mineral Springs SWG
    2 skimmers
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    Correct. No winterizing for us.
    Update-I spoke with a tech at Pentair; he said it may be from the diffuser plate (?). I did a search for Pentair diffuser plate bolts and sure enough, that's my bolt!! They'll send someone out to inspect repair under warranty.
    Thanks
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    Quote Originally Posted by midtngal
    I think you're right (either the impeller/diffuser). I'm guessing I may come home to a big mess
    Thanks
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    485
    If it's a fat screw (forgive me...I'm not a plumber or electrician! ), then it's the impeller screw. If it's a little bitty screw, it's from the diffuser plate. Either way, the question that needs to be answered is why did it get blown into the pump basket? THAT'S the bigger problem!
    What's even more pathetic is how I know this! Problems create education!
    10,700 gal IG vinyl
    2 skimmers
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    From the pictures I found regarding replacement parts for my pump, it's a diffuser plate screw. PB says that I have a 3yr-warranty and Pentair will most likely replace the pump and motor.
    An education indeed, but sometimes I hate the methods!
    Thanks for the help! Happy New Year
    Dave
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    485
    Yeah, Pentair is VERY good with their products and customer service. They replaced 4 pumps for me without a whole lot of hassle. As it turns out, I think it was all the pine needles getting through that was burning up the motors, but they replaced them!
    10,700 gal IG vinyl
    2 skimmers
    I'm not sure why the screw was out of place, however I think that it would only need to be reinstalled. I don't see any reason to replace the pump or motor if they are working properly.
    Support the site
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    Thanks for the input. Regarding repair or replacement, I'm easy and ok either way they want to fix it. Heck, If it does fail later-after warranty, the pump design seems good and with the twist connecting unions my PB used and low cost parts, I might consider repairing myself. Temporarily I guess I could always switch over and use my waterfall pump for filtering /circulation and really have time to get acquainted with the pump.
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    Re: SS Bolt Found in Strainer Housing-Repair Update
    Pentair certified Tech came out for warranty repair. The bolt was a impeller set-screw (reverse thread). He said it was odd for that to occur, but I'm good-to-go
    If you are getting air in the filter, the air can compress when the pump is on, and then when the pump turns off, the air can decompress and cause the impeller to spin backwards. That can create an unscrewing force on the impeller, which might have caused the setscrew to become loose. Once the setscrew is loose, the normal spinning of the shaft can cause the screw to back out.
    Air you getting any air in the filter, or from the returns?
    Support the site
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    Quote Originally Posted by JamesW
    Are you getting any air in the filter, or from the returns?
    Thanks for the reply. Some leaves a few months ago did in fact cause some problems. NOW I have an idea on what may have caused this set-screw to go AWOL.
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    485
    I would have to go back and find the post, but I don't remember why mine kept blowing out. I could screw it back in, put the motor back together, turn on the pump and in just a few seconds I could actually hear the screw hit the side of the basket!
    Quote Originally Posted by pragmatic
    It's actually very easy to do. I have installed all of my pumps except the first one. And I'm a girl!
    Glad it has ended well!
    10,700 gal IG vinyl
    2 skimmers
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    I would have to go back and find the post, but I don't remember why mine kept blowing out. I could screw it back in, put the motor back together, turn on the pump and in just a few seconds I could actually hear the screw hit the side of the basket! It's actually very easy to do. I have installed all of my pumps except the first one. And I'm a girl!
    Thanks for the heads-up and vote of confidence
