Thread: Winter Time Chlorine Levels
    May 2013
    Egg Harbor Twp, NJ
    41
    I had some calcium scaling issues last year when I opened my pool due to a rising pH in the pool while it was winterized (I'm in NJ). So, this winter I've been checking my pH every few weeks and adding acid as needed to try to avoid the scaling issues again.
    Anyway, when I checked the other day, I decided to also check the chlorine level. I was surprised to get a reading of 0! This was just the quick 5 drop test for chlorine, not the full TFT-100 test.
    Is a reading of 0 chlorine over the winter normal? Is it something to be concerned about? If needed, is there anyway to adjust it over the winter time, or do I basically just wait at this point for spring time to come and see what's awaiting me when I open it?
    Thanks for any help!
    25,000 gallon IG gunite pool with Diamondbrite finish built May, 2012
    All Pentair equipment:
    FNS Plus 48 sq. ft. DE Filter, 1 HP SuperFlo Pump, IntelliChlor IC40 SWG, MasterTemp 400k BTU/HR Heater, Prowler 820 Vacuum
    Test Kit - TF-100
    22,553
    Re: Winter Time Chlorine Levels
    If you can circulate in order to add acid, you can do the same in order to add chlorine. I wouldn't worry too much about it, but I hate to see zero FC at any time.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    It shouldn't be a surprise however. Chlorine is consumed year round, just a slower pace in winter time.
    Essential Links:
