Thread: Pebble in the pool sweep bag...
    Hello,
    I had an in-ground pool installed in October 2013. It's about 20k gallons and has a pebble plaster surface. I was curious how long I should expect pebble to be present in the pool sweep bag. There seems to be about 1/4 to 1/3 cup in the bag each week. Will there always be pebble in the bag due to the nature of the product?
    Thank you!
    Brand new pool owner
    Size of pool - appx 20,000 gallons
    Filter - DE
    Inground pool plaster/pebble
    (Not asked to be revealed but screened in pool enclosure)
    Do not know flow rate of pump
    22,551
    Re: Pebble in the pool sweep bag...
    Welcome to TFP.
    Are you sure what you're seeing is from the surface of the pool?
    ¼ cup per week isn't much but there shouldn't be any (or only a minute amount) coming from the surface at this time.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    That does sound excessive, especially this far out.
    Essential Links:
    38,305
    I used to get a good bit of pebbles too. I was still seeing some over a year later, BUT I think I have realized that most/all of it now is just sand that is kicked / washed in from around the pool.
    I think it's definitely pebble from the pool. There's only patio and bark around the pool itself. The chemical levels seem okay but I think I may call my builder just to be sure... though there's not much they'll be able to do about it, I'm sure. The pool is about 50 degrees F atm.
    Filter - DE
    Feb 2011
    Petaluma, Ca
    665
    I have only seen about 1/4 cup total in the last couple years, do you see a lot of "holes" where the pebbles are dislodging from?
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
