Thread: Hi from New Zealand
    Jan 2014
    Wellington, New Zealand
    11
    Hi from New Zealand
    Hi guys,
    This is my second year with a pool, it's a small pool but great for my little kids, and not bad for dad to cool off on a hot day either.
    The first year I knew nothing and just threw a couple of 1inch chlorine tabs in the floater each week, and nothing else. I got lucky and had no problems at all. This year not so lucky...went away for a couple of days and came back to green water. Threw truckloads of chlorine in there until it wasn't green any more, but couldn't get rid of the cloudiness, so drained and refilled.
    Learning quite a lot here so far so hopefully won't have to do that again. Anyway, enough chit chat...back to reading.
    10' Bestway above ground (vinyl) pool - Water capacity 4,678L (80%)
    Intex Cartridge filter - 530 Gallon per hour
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Hi from New Zealand
    Welcome to tfp, wayneb
    Sounds like you have found pool school
    Let us know if you have any questions.
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the forum
    You're done SLAMing when:
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP!
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Welcome to TFP !!
    Jeff
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Welcome to the forums.
