Results 1 to 13 of 13
Thread: help! need new filter
    Dec 2013
    Orange County, CA
    30
    my de filter has developed a leak/hole on the stainlss steel body. I need help picking out a new filter. I am currently using a diatomaceous earth filter. i don't know where to start or what size for my pool spa 28k gal.
    would something like this work?
    http://www.amazon.com/s/ref=sr_1_1_acs_ ... 1389571704
    Pool Specs: 26K, IG, Plaster, Hayward 1HP Superpump, Hayward ProGrid DE 6020
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Re: help! need new filter
    Mine did the same thing this summer, i replaced it with a hayward DE filter,
    They sell them by Sq. Ft. .. Your old one should say how many .. 48,64 , 72 are commen.
    pentair also makes a good one..
    Determine size you need and shop around. i have never used a pentair filter, I have had 2 haywards over the years and the work well and are easy to find parts for.
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    38,262
    You link did not work for me to a specific filter.
    What size was your current DE filter?
    What size and model pump do you have?
    Given the size of the pool and that you are open year round, getting a pretty good size filter will reduce the frequency of cleaning.
    So rough sizing would be:
    300+ sqft cartridge
    30"+ diameter sand
    60+ sqft DE
    Depending on your pump size, bigger would not really hurt anything but costing a bit more money.
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    check out this one
    Sean Hannon
    Dec 2013
    Orange County, CA
    30
    my original one is 60 sqft. i was looking at the hayward and pentairs, and it looks like hayward is cheaper.
    anyone know if its easy to install with existing copper piping 2"? was thinking of cutting and joining it to pvc. I'm pretty handy but want some advice with this.
    i have a old school purex AH-8 pump. it works fine but its old single speed. that may get replaced later.
    lol the plaster job isn't finished yet so ill have to get this asap. does anyone know if you can leave a finished plaster job for several days without pumping water in?
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    the hayward requires the multiport valve , its shown but not included.
    Sean Hannon
    38,262
    You need to get the pool completely full immediately after the plaster job if that is what you mean.
    You also want to get the plaster particles in the water filtered out pretty quickly as well or they will stick and make the surface rough (unless you brush often to keep everything suspended in the water).
    Dec 2013
    Orange County, CA
    30
    they will be doing startup and brushing for me.
    38,262
    You are going to want to get that pumping and filtering as soon as you can.
    Dec 2013
    Orange County, CA
    30
    Quote Originally Posted by Seanhan
    what's the difference with the slide valve with two options vs the multiport with like 6? is the multi necessary over the slide? my previous filter was just backwashand filter (two options)
    Dec 2013
    Orange County, CA
    30
    ok.. so for the pump, i don't have the pump HP in front of me, but it was a purex AH-8 . i cant find info on how much HP this is but i'm thinking of changing this while i am at it.
    thanks.
    38,262
    The multi port has a waste function and recirculate function and rinse function that can be helpful ... especially the waste.
    Nov 2013
    Northern New Jersey
    36
    what about the Pentair Quad, both DE and Cartridge hybrid?
    30k gallons , In ground Plaster Hydrazzo, Pentair Quad 100 DE/Cartridge Hybrid, 2 Pentair Intelliflo, Install 5/2014 , Taylor K-2006, SWG IC-40 Pentair Easytouch 8, Intellichem w / acid pump, Solar Fafco & Pentair Gas Heater, The Pool Cleaner suction side.
