Results 1 to 13 of 13
Thread: Does newly sprayed gunite have to be watered in the winter
    Dec 2013
    Arlington, TN
    5
    Does the gunite still have to be watered in the wintertime to help with curing? My build is in a suburb of Memphis. PB said you shouldn't have to and he uses a 7 bag mix.
    96 foot Perimeter 34' x 19' x 15' gunite pool with 400k heater and 7 foot spa
    5 Returns, 2 heating returns, 2 skimmers, 2 main drains
    Diamond Brite Super Blue plaster
    Pentair intellichlor IC 40 SWG with Delta UV with CC520 cartridge filter
    Two Intelliflo VS 3 HP pumps
    Readyforapool's Avatar
    Sep 2013
    DFW metroplex
    738
    Re: Does newly sprayed gunite have to be watered in the wint
    PB had me water mine twice a day and temps were in the 40's and high 30's - got lucky a few days when it rained.
    Finally Done! - 21x34 IG, SWCG, depth - 3.6 - 4.6 - 6.6, Pentair IntelliFlow 3050 vs+svrs, 60 sq ft Pentair DE Filter, 400k BTU Heater, Polaris 280 w/.75 hp booster pump, Pentair EasyTouch wireless, 38 sq ft raised spa, wet edge Barbados quartz finish - ODK w/36 in Napoleon grill
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    It is probably still a good idea, and can't possibly hurt.
    Quote Originally Posted by Backyard Haven
    I am in a Memphis suburb as well, and no watering taking place outside of the rain.
    I would have rather water the **** out of it, than scrub the plaster twice a day in 30's weather. Brrrrrrr. my hands are still numb.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Mines an 8 bag mix completed last week, and he had us wetting for the first three days. After that, it doesn't matter, it's done.
    Essential Links:
    Dec 2013
    Arlington, TN
    5
    Thanks for the replies. PB says either this week or next week we will outline the pool in my backyard for my review then excavation begins. It is crazy temps here daytime highs 40 to 50's and lows at night in the 30 to 20's. I am a little worried about the gunite curing with such temperature fluctuations. Maybe the temperatures will be more consistent by the time they spray the gunite.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Don't worry, it will be fine. Also, the cement plant won't send it out if it's too cold.
    Essential Links:
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    Our pool was shot at 27 degrees (the high for the day), with big variations after that - and no watering - just rain. It hasn't cracked open yet! Was there any effect, dunno. Not worried, life it too short.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by bmoreswim
    I like your outlook and you are right, it's way too short......and you sure won't stop it anyway. It's funny though, down here the plant won't send out a mix if it's less than 32F.
    Essential Links:
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    That would make sense about not sending it out since they wouldn't be as well practiced in making any required adjustments to the mix. Better to just wait a day or two.
    Dec 2013
    Arlington, TN
    5
    Lucky they have not begun excavation yet. Since supposedly another arctic vortex is coming.
    MiaOKC's Avatar
    Apr 2012
    Oklahoma City, OK
    347
    Not to hijack your thread, Backyard Haven, but I am really worried about this, too. My father-in-law is telling me not to let PB do any concrete work if the 3 day forecast dips below 40 degrees, he says the concrete will not cure properly and will have a much-shortened lifespan (we are rehabbing an existing pool, so this is not the shell concrete, don't know if that is different). Of course, icy weather delays have put us way behind schedule and now that it is dry (but COLD - 3 day low is 25) PB wants to pour concrete coping and decking. Google seems to agree with my father-in-law and not the PB.
    35,000 gallon gunite pool, semi-T-shaped, 29x15 shallow end and 16x22 deep end, built in the mid-1970s and renovated 2013-2014 // Polaris 9300 Sport robotic cleaner // Taylor K-2006 ... Learning as we go and so grateful to everyone here for their help! Our reno thread
