Results 1 to 8 of 8
Thread: Preparing for RO.
    Dec 2013
    Temecula - Southern California
    26
    Preparing for RO.
    I have arranged for RO treatment of my pool due to CYA=300 and CH=950. I was wondering what things I should do before the RO and to prepare for the process. I was thinking of cleaning the calcium deposits on the spa overflow and water feature. Anything else people can suggest?
    Thank you.
    20k gal, IG gunnite plaster + spa, 2 HP Whisperflo pump, Pentair 520 sq ft catridge filter
    Pentair Min Max NT heater. Intelli-touch i5 controller, Ultrapure ozone (currently disabled), Rainbow 320 chlorinator
    Small water feature, Water slide. Poolvergnuegen 2WD suction cleaner.
    38,251
    Re: Preparing for RO.
    I don't think they can do it if the water is cloudy and green. I don't think there is anything you "have" to do before they come, but probably should ask them.
    You sure that replacing the water is not the cheaper stilton?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I would suggest asking your RO provider what they want you to do. Some require there be no chlorine in the water (some RO membranes break down when chlorine is present, however some of the newer ones are much more chlorine resistant ), in general they all require the water to be clear and not cloudy, etc.
    Ike
    Dec 2013
    26
    When I spoke with the RO company they did not request any preparation. Their biggest concern is getting the CYA down, as their machine uses TDS to determine when the water is "clean". They mainly deal with high CH issues in our area so are not completely sure how CYA acts on TDS. I was not planning on adding any more chemicals to the water until they come in a weeks time. My question was more about what other tasks would be useful to do. For example cleaning the calcium deposits my thoughts being that any spill over into the pool will be removed by the RO.
    As for draining the pool, I estimate that would be much less expensive than the RO, but my area is low on water, so I don't it is reasonable to dump 20,000 gal of water.
    Jun 2011
    Long Beach, CA
    2,778
    What you want to doing is fine, but my question for you is, do you understand why the CYA got so high and what do you plan on doing to keep it from getting too high again?
    Dec 2013
    26
    We have been in this house less than 2 months. The previous owner had the pool maintained by a "pool guy" so I guess the high CYA is due to heavy use of tablets (there is an auto chlorinator on the pool). I have been using liquid chlorine and plan to continue doing so.
    Jun 2011
    Long Beach, CA
    2,778
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Cya will add very little to overall TDS. Very little.
    Essential Links:
