Thread: Heavy snow melt now water tubes and cover in pool
    Mahomet, IL
    16
    After heavy snowfall and now rain and melting, my cover is too heavy and several water tubes and one side of the cover have slipped into the pool. What's the easiest way, if there is one, to get them back out? And how far below my skimmer line is safe to keep the water level. Since I cannot see under the cover, I think I keep the level too low out of fear water will get into my lines. Thanks!
    Becki
    Newbie with an in-ground, 37,000 gallon vinyl liner, sand filter.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Heavy snow melt now water tubes and cover in pool
    Your lines should be sealed, so there shouldn't be any worry about water getting in them. I drop my water to the bottom of the skimmer when I close, then drain it back to the bottom of the skimmer during warm spells in the winter, but it's not critical.
    Getting the cover and tubes out will be difficult. You may be just as well off to wait until time to open the pool. An uncovered pool isn't a big deal once leaves are done blowing around unless you wait until summer to open.
    Mahomet, IL
    16
    Thank you! We got the tubes off but the cover is frozen in the snowmelt on top of it. My skimmers did not have plugs or seals. They are Aquagenies that have the skimmer and jets all in one. I've tried to find plugs or seals but no luck so far.
    Becki
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Quote Originally Posted by rsalzman
    Aqua Genie makes a plate that mounts onto the front of it for winterizing. The winterizing plate is about your best choice for a Aqua Genie
    http://www.1stoppoolsupply.com/aqua-gen ... 18218.html
    Disclaimer: I am not endorsing the posted website. It is for reference only for what the winterizing plate looks like.
    Divin Dave,
