Thread: water above coping
    Jul 2012
    Whidbey Island, WA
    397
    water above coping
    lotsa rain today in the NW and I am not at the pool
    does anything bad happen if the water level is up on the coping?
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: water above coping
    Your skimmer won't work well, but otherwise no big deal. Chemistry will probably be a little off with the extra water.
    Jul 2012
    Whidbey Island, WA
    397
    thank you
    I thought I saw something somewhere about water in around behind under the coping
    but good
    I will just drain some next week and call it good
