Thread: 15 below now after first thaw leak
    Makdaddy's Avatar
    Jul 2012
    Springfield Illinois
    119
    So I went out to pump water off the cover
    I have a dribble from the return
    Now I left my pool full and used one of those expandable tubes for the skimmer
    But I just used a plug for the return
    Could it have frozen and cracked?
    Plus now I need to figure out a way to keep the water away from the base of the pool its dripping real steady.
    My cover goes over the sides and covers the return not sure If I can get a hose on it or not
    --- Greg----
    24 x 54 Round Cozumel AGP with Grand Entrance Step 14500 Gal
    Running ntex Krystal Clear Saltwater System with E.C.O.
    A/G Cristal Flo II Sand Filter Tank w/ 2HP, 2-Speed Dynamo pump -Zeobest
    TFT Test Kit---Gorilla Floor and Foam Pool Cove--Half Deck
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,086
    Re: 15 below now after first thaw leak
    Did you drain/ blow out the lines before closing?
    Makdaddy's Avatar
    Jul 2012
    119
    Quote Originally Posted by Leebo
    Its just the 3 inch connector that the hose goes to to fill the pool from the pump.
    I have a screw in plug on the inside of the pool.
    It is leaking in that pipe ,so I assume the screw in plug (seal) broke or cracked.
    Im looking at some Conduit plugs , they are like putty, that might seal it till spring.
    --- Greg----
