Results 1 to 7 of 7
Thread: High Pump Pressure
    High Pump Pressure
    This is my first winter with my pool up and running. It seems over the last couple of months my pump pressure has increased from around 20-21 to about 40. I did a backwash which in the past has always returned it to the 20-21 range. The pressure remains at 40. What can this be caused by and what is the solution.
    19,800 gallon Leisure Pool, Moroccan. Fiberglass. Pentair 1.5 HP SFN1, Pentair Intellichlor Chlorine Gernerator, Sand filter, Maytronics Dolphin Supreme M4.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: High Pump Pressure
    Does the pressure gauge go to zero when you turn the pump off?
    38,274
    Sounds like a bad gauge. 40 is near impossible to get.
    Checked the gauge and it seems to be stuck at 18 so that explains the high pressure. Thanks for the replies.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Get a liquid filled gauge. They last much longer.
    liquid-filled-pressure-gauge-inexpensive-8-19-9-12-13-t54701.html
    38,274
    Apr 2011
    Murrieta, CA
    2,360
    Get them from Dave! Didn't know that he's carrying them.
