Results 1 to 11 of 11
Thread: Threaded PVC Question
    Mar 2013
    CT
    351
    Simple question - If I use threaded PVC going into my pump - do the threads normally get Teflon tape??
    Thanks!
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    22,553
    Re: Threaded PVC Question
    Well, maybe. I prefer paste, but they should have a sealant applied to them whatever you use and prefer. If that's t-tape then yes they get taped.
    Mar 2013
    CT
    351
    What type of sealant could I use to replace the tape? I'm re-plumbing my system and it looks like the prior owner did use sealant as you can see if all over the threads...
    22,553
    Teflon based sealant for plastic pipes is what you should use. There are several brands so just get whatever your local store carries. Just make sure it's for plastic piping.
    Jul 2013
    Mesa, Arizona
    86
    Some here will disagree with me, but the threaded fittings manufacturers recommend -never- using tape, only a good PVC thread paste/sealant.
    But by all means yes, use a thread sealant for your pump connection.
    Mesa, AZ Spillover spa and inground pool, 12,500 G, pebble finish, Hayward C5030 (525sf) Cartridge Filter, Hayward EcoStar VS Pump, Installed July 2013, Hayward SWG T-Cell-15, Trident UV (I know, I know....was installed before I found this site!) Rock grotto waterfall, LED ColorLogic lighting, 110 BTU Heat Pro Electric Heat Pump, Maytronics Dolphin Supreme M5 cleaner, TF-100 test kit with Speed Stir.
    Nov 2011
    Moberly,MO
    1,010
    Not arguing about manufacturers recommendations, but we have used teflon tape for over 30 years on all our threaded fittings and haven't had an issue. May not be the correct way to do it but that is the way we have done it.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Jul 2013
    Mesa, Arizona
    86
    Quote Originally Posted by swimcmp
    Yup. I know it will do just fine for a pro, but the sealant is much more goof proof for Average Joe.....it's pretty easy to under wrap or over wrap with tape, but paste sealant is "self-adjusting".
    Male PVC into Female Metal are fine for tape, but I would never recommend using tape in PVC to PVC threads, unless you're in a pinch......
    30,431
    The argument of "tape" vs. "pipe dope" is as old and unsolvable as is the argument about which type filter is best.
    I prefer to use "dope" on anything an inch or more....teflon on the smaller diameter. I can't tell you exactly why, it just seems to work better for me.
    The point is, how ever you are used to doing it is the best way. If you are not used to threaded PVC at all, dope is probably a little more bulletproof and "self adjusting" as stated above.
    Jul 2013
    Mesa, Arizona
    86
    I agree with you Dave.....it doesn't hurt to explain to any "newbies" a best way, however.
    To each his own, and if it ain't broke don't fix it, and if it works for you, etc. etc. ad nauseum.
    It's just as a manufacturer and supplier of this stuff I can definitively say that versus any warranty claims, if tape was used and it failed, we're off the hook.....
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Another guy that uses thread sealant. It's just what I prefer. Never had any leaks using it.
    Jeff
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Here's what some manufactures say:
    http://www.lascofittings.com/threads
    http://www.spearsmfg.com/how_to/FG-3B-0 ... nglish.pdf
    I didn't have sealant, used tape. 1 1/2 fittings. Working ok.
