Thread: Manual Operation of SWG
    I had a question on manually operating the the SWG. Currently, I have a breaker box by the pool equipment pad that has a 220 breaker going to the pump and another 220 breaker going to the SWG. When I have been doing is turning both of them off and on with the breaker (not so much on the SWG during the cold months).
    Should I be powering the SWG off and on with the breaker of should I just leave it on all the time? I do have a flow control on it and its a Hayward Aquarite with a TurboCell T-15.
    Thanks
    27K Vinyl IG Pool
    18x36, Aquarite with Goldline T-15 SWG,
    Hayward 244T Sand Filter, 1.5 HP Hayward Super Pump w/ AO Smith B129 Motor
    Taylor 2006 Test Kit
    NW Louisiana
    38,371
    Re: Manual Operation of SWG
    The SWG should only get power when the pump is on. So you should rub the pump and SWG off the same breaker ... that is the correct and safe way to wire it.
    The flow switch should be considered more of a back up safety switch.
    Curtsam's Avatar
    Aug 2013
    Eastern Oklahoma / Arkansas
    33
    No wear on the Cell if the water is too cold to make Chlorine?
    In other words, no problem running the water through the SWG in winter? Doing so will not effect the life of the cell? Just add liquid chlorine as needed?
    2014, IG 20,000 gl 18x34 Vinyl Liner / Waterfall / SWG / Sand Filter /
    Dolphin M4 Robot / TF-100 Test Kit is used / Beer is consumed /
    *Stamped Concrete Decking*
    38,371
    No. No. No. Yes.
