Results 1 to 8 of 8
Thread: How much can I drain my pool?
    I have a 24 ft above ground pool. My pool looked like a swamp when I opened it. It also had alot of debris at the bottom. I was told by a pool company not to drain my pool? I have read your forums and could not find any information on this subject with above ground pools. How much of the pool can I drain to get the debris out of the bottom? I was told if I drained it the liner would shrink. I really do not know any other way to get it out. Also I was told it I put new sand it the filter it will help clear the pool. Thanks jdeltateacher
    Casey's Avatar
    SW PA
    10,448
    Re: How much can I drain my pool?
    You do NOT need to drain your pool! All you need is POP *pool owner patience*, a leaf rake and lots of bleach for shocking, a pool brush to brush the sides and bottom and running your pump 24/7 til it clears.
    If you drain it, you may run the risk of ruining the liner and causing your walls to collapse. It is un~necesary!
    See my article on cleaning up a green swamp for detailed advice on cleaning up your pool.
    Quote Originally Posted by Casey
    Thanks for the info. Could you give me some information on how to change the sand out of my pump? I have a waterway. Thanks
    Casey's Avatar
    SW PA
    10,448
    I'm sorry. I can't. I don't know a thing about them. I have a Hayward DE.
    Someone will be around shortly to help. (They really know their stuff! 8) )
    Hope you can get swimming soon!
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by jdeltateacher
    How old is the sand in your filter? It usually lasts for years....and years.
    Welcome to the forum
    You're done SLAMing when:
    Quote Originally Posted by jjparrish
    Three years jdeltateacher
    Butterfly's Avatar
    South Carolina
    10,045
    Did they give you a reason for needing to change your sand?
    If it was my filter, I would not change the sand just because someone at the pool store said that I needed to do so.
