Page 1 of 3 123 LastLast
Results 1 to 20 of 51
Thread: Motor making new noise; bearings?
    Dallas, TX
    227
    http://youtu.be/J1UidKL63SE
    Just started. Been running for about 3 days straight with the freezing temps.
    I can get the model info tomorrow. Any ideals? Does it hurt to run it like that? Don't want tonal emanating worse.
    new house: TBDK gal IG plaster pool, filter Titan CM DE filter 36 sq ft , 1.5 HP Pump; Polaris 380
    Dallas, TX
    227
    Re: Motor making new noise; bearings?
    Here is the label. Turns out I had a picture of it on here when it was installed. It is 3 years old. [attachment=0:1nzma0id]ImageUploadedByTapatalk1389150874.496126.jpg[/attachment:1nzma0id]
    Smykowski's Avatar
    Sep 2011
    3,065
    Yep, sounds like bearings. Bad bearings will kill a motor eventually, so you can't let it run like that forever, but you don't have to change them tomorrow.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Picture worth a thousand words. What about a video:
    http://www.youtube.com/watch?v=UhhNk5tH9NI
    http://www.youtube.com/watch?v=uxTlCZ9SfqM
    Parts:
    http://wetheadpumprepair.com/store/prod ... it-001401/
    You may want to call to confirm the bearings.
    Dallas, TX
    227
    Awesome thanks. Just had a buddy replace his. Far as I know it just started making the noise so I'll get to it soon.
    Dallas, TX
    227
    Just got a reply email from the people at wethead.com. They said the kit I needed was the one below. I didn't see any ones that said century on the website so I guess this is just a comparable piece that fits that motor?
    http://wetheadpumprepair.com/store/prod ... epair-kit/
    Smykowski's Avatar
    Sep 2011
    3,065
    When I did mine, I just got them from Grainger. Depending on how fast you need the pump turned around, you can tear the pump apart and look for any markings stamped on the bearing seal to make sure that kit matches.
    Dallas, TX
    227
    Should you always change the seal when changing the bearings?
    How did you know which bearing to get at Grainger? Take it apart and take the bearing with you?
    Smykowski's Avatar
    Sep 2011
    3,065
    General recommendation around here is yes. Full disclosure, I've done it both ways. I've got two pumps, and I've had to disassemble them several times for various reasons. I'd say I replaced the shaft seal half the time. In the times I reused the seal, I haven't had a problem.
    That said, it's a wearable item, so if there's any age on it at all, it makes sense to change it while you're already in there.
    Apr 2011
    Murrieta, CA
    2,360
    Looks like the bearings are 6203 Double Sealed for both ends Century part #10000353. (Some use a 6203 and 6204 bearing.) Looks like the kit earlier comes with 2-6203 and 1-6204 and the seal.
    The are very common can be found for less than $10 for a set of 2, but you'd still also need a new shaft seal.
    Check eBay for 6203 2rs seal
    I'm partial to these: http://www.ebay.com/itm/6203-2RS-Premiu ... 1125228165
    The company is local to me. I've done business with the company in the past.
    Smykowski's Avatar
    Sep 2011
    3,065
    I'm with bobo.....Grainger for the bearings and eBay for the shaft seal.
    Dallas, TX
    227
    I can't seem to find the seal on eBay. All i get when i search 6203 2rs seal is sealed bearings. Is that what i want? i think it might be it's just looks like a bigger version of the bearing it confused me. I've never done this before.
    For Grainger, i found these. They look correct, yes?
    http://www.grainger.com/product/DAYTON- ... =P2IDP2PCP
    REALLY appreciate all the help
    Apr 2011
    Murrieta, CA
    2,360
    Quote Originally Posted by CarrolltonTXPool
    I don't think those are the right ones. They have a metal shield, not a rubber/plastic seal. You want the sealed bearings not shielded.
    I believe it's this one:
    but it's cheaper here:
    I'm not positive on your pool pump type (wet end): but if it's a Sta-Rite Dura Glas Pump Shaft Seal 17304-0100S, S-200
    this is the seal you need:
    http://www.ebay.com/itm/Sta-Rite-Dura-G ... 1c0d7f131d
    You'll need 2 bearings and one shaft seal.
    Dallas, TX
    227
    Yeah that's the pump I have. Thanks for all the help!
    Smykowski's Avatar
    Sep 2011
    3,065
    Please post back when you're done. We need more examples of people who overhaul their own pump. Unfortunately, too many people want to just replace the pump (and pool shops advise this route VERY quickly, obviously), instead of saving a ton of money and fixing it themselves.
    Dallas, TX
    227
    Will do. Got the seal today and the bearings come Thursday. Hoping to have my buddy come over sat morning to give it a shot.
    I agree about the pool store. Last time I had an issue they give me the standard "well if that part went, it's only time before the whole thing breaks. I wouldn't waste money replacing parts when you'll need a new motor anyways."
    Dallas, TX
    227
    Got it almost put back together today. New bearings and seal are on but the impeller screw was trashed in the removal process. Do hardware stores usually carry reverse thread screws? Thought about swing if Leslie's had one in stock. Need to get ASAP to get pump back working before the next cold snap
    They have it here for $6.99.
    http://www.yourpoolhq.com/sta-rite-dura ... 7AodEFQA4g
    Apr 2011
    Murrieta, CA
    2,360
    Did you take any pictures?
    Dallas, TX
    227
    Quote Originally Posted by bobodaclown
    Unfortunately, no. My help had to leave to help another buddy with a broken car, so I was under the gun to finish before dark.
    We will see if it runs ok, but I am not very mechanically inclined and with the resources out there I didn't feel over whelmed during the process. The bearing puller was a little tricky but the videos online helped. Rented it from O'Reileys for a refundable deposit.
    Picked up a new screw at a local pool store so will fully reassemble tonight and hopefully reinstall tomorrow.
  20. Back To Top    #20
    Dallas, TX
    227
    Ok get the impeller screw on, put on the diffuser and the shaft stopped spinning. Took it off and there is rusty looking stuff on inside rim. That has to be it, because it totally spins free with the diffuser off. Unless it developed I the two days it's been apart, it was there before and spun. Not sure why this changed. Any ideas? It was more of a green color so I used some emery cloth then a small screw driver to chip away. But still some on there. [attachment=1:3tx47iry]ImageUploadedByTapatalk1390265066.189805.jpg[/attachment:3tx47iry][attachment=0:3tx47iry]ImageUploadedByTapatalk1390265075.605829.jpg[/attachment:3tx47iry]
