Thread: Pool equipment questions, including salt system?
    Elgrecus's Avatar
    Feb 2013
    Los Angeles, CA
    57
    I am an architect working on a project for a custom home in Los Angeles that has a pool with integrated spa. The owner would like to use a single heater for both pool and spa. TFP has helped immensely with my own pool so hopefully someone can give some advice on the following questions.
    1. What salt system should I use based on the other specified pool equipment for the project? I have an Eco-matic but the I am not sure if that is recommended based on the mostly Pentail specs below.
    2. Can I use a single pump for both pool and spa?
    3. Can I use a single filter for both pool and spa?
    4. Can I use a single heater for both pool and spa?
    5. Does the Pentair pool control work like a Jandy remote? Is is just a mobile device app or do they make an actual physical remote?
    Here is my current spec:
    Pool/Spa Pump
    Manufacturer: Pentair Pool Products
    Product: Intelliflo Variable Speed Pump
    Model: 011018
    Pool Filter
    Filtration: Clean and Clear Plus Filters
    Product: 160332
    Model: CCP520
    Spa Filter
    Product: 160340
    Model: CCP320
    Pool Heater
    Product: MasterTemp Heater
    Model: 460736
    Spa Blower
    Manufacturer: Air Supply
    Product: Outdoor Spa Blowers
    Model: Silencer, 2.0 h.p.
    Water Leveler
    Manufacturer: Zodiac
    Product: Levelor Electronic water leveling system
    Pool Equipment Controls
    Product: Easy Touch 8 function pool and spa controller w/IPad interface
    Pool and Spa Cleaner
    Manufacturer: Blue Square
    Product: Q360 In-Floor System
    Color: To be determined by Architect
    Pool and Spa Skimmer
    Manufacturer: A&A Manufacturing
    Product: Ecoskim
    Pool Lights
    Manufacturer: Hydrel
    Model: 4426 LED Wet Niche Monochromatic Pool Light
    Thanks in advance for your help!
    Pool Size: 9,000 gallons
    Pool Type: In ground, plaster
    Filter: Pentair 4000 Series D.E. Filter
    Pump: 1 HP Pentair Whisperflo WFE-4
    Heater: Sta-Rite Max-E-Therm 200
    Salt System: ECO-matic ESC 36
    Pool Cover: CoverStar, motorized cover
    Re: Pool equipment questions, including salt system?
    Pentair IC40 Salt Cell
    There is an easytouch system that comes with the IC40:
    http://azwholesalepoolequipment.com/180 ... 520545.htm
    (I'm not affiliated with this company)
    Stick with pentair and get the full 3 year warranty
    Will
    38,275
    Beware that many companies are now vastly limiting the warranty period if the equipment is not installed by a professional. I think you can still get the Pentair 3 year warranty with 3+ pieces of equipment bought from the same place at the same time if installed by a professional.
    Mar 2010
    122
    Using the same pump and filter for both can be tricky if the spa doesn't spill into pool. It can be done I have a customer that has it set up this way. But since they already have a filter for spa I would go ahead and do a smaller pump for the hot tub. Idk what everyone else's thinks about that but I found it hard to get the valves just right to where it wouldn't drain the spa, or make it over flow on my customers spa and pool when he has it on the same pump and filter
    Jacob Zaluski, Owner
    True Blue Pools LLC. Lexington, KY
    Service Center for Hayward Pool Products
    poolkid's Avatar
    Mar 2012
    Mesa, AZ
    77
    Jason is correct. Take a look at this article explaining the changes to warranties by the "Big 3."
    http://www.poolspanews.com/retailing...fpzone=general
    "Pentair Aquatic Systems recently revised its long-standing program. Warranties on a number of Pentair’s products — including pumps, filters and heaters — will be limited to 60 days unless the equipment is installed by a certified professional. In that case, it will be protected for one to five years, depending on the product. In the past, Pentair offered repairs or replacements for a full year or more, regardless of who performed the installation."
    APSP Certified Building Professional
    APSP Certified Service Professional
    NSPF Certified Pool Operator
