So here's my quandry...I'm in Tennessee...we're at 8 degrees right now on Monday night. I cleaned out my skimmers this weekend in preparation for the freeze this weekend since I knew I would have to keep the pump running. Baseline pressure is 10psi on a normal day.
I just went outside to check on things and make sure the pump is still running before bed since we're getting down to 8 degrees tonight and water is rippling on the top of the pool...pump is running...everything looked good until i noticed the gauge is at 0. I looked closer and noticed that not only is the needle at zero...but it appears to be underneath the little metal needle rest. I'm not sure if this just means my gauge is broken from the cold or if my filter is running at such high pressure that it's wrapped all the way around above 80psi and is essentially "pegged". One more note...I noticed a very small/slow leak around the top of my filter a month or so ago. I took pictures and asked my pool guy for advice. He said such a slow leak could be safely dealt with in the spring. He said if I started messing with it now I would likely crack something with the cold and that as long as it was just a drip and not a spray of water it was fine to leave until spring. So I've got some ice around the top of the filter where this water was leaking. Is it possible the guage is just pegged because some ice is trapped right underneath it? It's obvious that the filter isn't frozen solid because my jets are on and blowing and the pool is rippling.
I'm not sure what to do. If I stop the pump everything is going to freeze up solid tonight and tomorrow...but I also don't want the filter to explode on me. What would you guys do?
