Thread: Pool Open During Winter - Freeze Coming
    Oct 2011
    Mebane, NC
    19
    I leave our pool open during the winter in North Carolina. A freeze is coming and I need to know whether or not there is something that I should be doing to prevent pipes from freezing. The pipes are 2" PVC. I always turn on the pool pump when the temperature goes below freezing. But this freeze is supposed to last for about 1.5 days starting tonight. Will I be OK with just running the water through the pipes? Thank You!
    20 x 40 IG 26,000 gal. vinyl
    Hayward sand filter S244T 62 GPM
    Hayward 2.0 hp Super Pump Mdl SP2615X20
    T-100 Kit
    Pool School
    30,395
    Re: Pool Open During Winter - Freeze Coming
    It's always a bit of a **** shoot but pump running should be fine.
    Covering the equipment with a tarp and putting a bulb underneath may be worth doing as well, but running your pump is most important.
    Oct 2011
    Mebane, NC
    19
    Thanks! I have the pump going. Not looking forward to 9 degrees! Brrrrrrrr
    T-100 Kit
    Pool School
