Thread: During freezing temperatures-Pressure rise to 80 PSI!
    Quote Originally Posted by JohnD5000
    I am currently running my pump to keep pipes from freezing in 28 degree overnight temp. However, I have some waterfalls that I have not diverted water to for 1 month. Should I divert water through all these pipes too? Will it matter? Thanks.
    Hello! First time pool owner and have questions about below freezing temps. I'm running my pool filter/pump tonight because the temp. right now in Fort Worth, TX is 14 degrees. I was told to always run filter when freezing weather is expected. However, the pressure meter on top of the tank/filter is reading very high--like in the 80 psi range. I removed all leaves/debris from around pool drain and cleaned out the skimmer baskets but the meter is still running high. Can this mean freezing is occurring? Yikes! Will await a reply.
    Orlando V.
    Fort Worth, TX
    30,415
    Re: During freezing temperatures-Pressure rise to 80 PSI!
    Pool pumps are not capable of 80 psi (only about 35-40) so the first thing is to fix the gauge.
    Secondly, do you have normal or close to normal flow in the pool?
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP!
    I recently experienced a similar situation, although in my case it was obvious that it was the gauge since it read 30 PSI with the pump off. Water flow was normal. Replaced gauge and all is well.
    Jan 2011
    Richmond, Texas
    595
    I had to replace my PSI gauge after the 2011 freeze we had here. It was reading 90 all of the time.
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Yes the gauges can freeze and yes they do fail and quite often. Let it warm up during the day and see if changes. If not, replace it. The oil filled gauges are little bit more resistant to problems so you might go with that instead. See tftestkits.net.
    Mark
